Old 11-02-2011, 12:47 PM   #276
slick copper
slick copper's Avatar
Re: Project...praise the lowered
That hood looks smooth! How are you gonna have it lift? Hinged to front, back, or side or lift off? Just curious. Good progress though!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 11-30-2011, 09:12 AM   #277
rchavez101
rchavez101's Avatar
Very cool great job.
94 Chevy SWB in progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=477390
rchavez101 is offline   Reply With Quote
Old 11-30-2011, 02:11 PM   #278
darkgable79
Do you have a detailed thread of building the center console? I'm interested in something like that. Thanks.
darkgable79 is offline   Reply With Quote
Old 12-01-2011, 03:17 PM   #279
hot rod mini truck
very nice build man!! i cant wait to get bags on myn
hot rod mini truck is offline   Reply With Quote
Old 12-03-2011, 08:52 PM   #280
(joey)
(joey)'s Avatar
its been a while since i have dropped in here.been so busy lately i haven't been able to pick up a wrench. thanks again for more comments fellas.in the new year my buddy is going to let me move back into his garage so i can finish it up.as for hinges in going to install some in the back.they will be custom.
and for the center console i will try to think back and give you a step by step.it was actually quite easy to build.hardest part was getting the right measurement for the shifter and hand brake holes.
1st step...i got my measurements of the length and height i needed to work with and cut a rectangle out of thin press board with that measurement.you could use cardboard.
2nd step...i trimmed the rectangle at the rear to fit the back of the cab perfect and the front to fit up to the underside of my dash.
3rd step...i had an idea of the shape and just marked out the flat lines of the place where the shifter would stick through then the step up where the arm rest would be.then just traced circles from various things laying around to get the flow i needed.
4th step...after cutting the shape out of the press board i traced in onto sheet metal (18ga) then cut it out (make both sides the same)
5th step...i used 1 inch wide x 1/8 thick flat bar on its edge and tack welded it to the whole top edge of the side pieces.this is where the top sheet metal will set on for sturdiness and will give a backing for welding the seams
6th step... i just figured out how wide i needed the console and used a soft measuring tape to see how long i would have to cut the top sheet metal to cover the top.
7th step... once the top was cut i began to get a rough shape of where i needed to bend it to fit to the sides.i just laid it against the side and marked where one bend had to be,bent it over my thigh (crude but it worked) then kept moving onto the next bends.
8th step..i worked with one side and the top and tacked it from one end to the other.this is where you lay the edge of the top on the side flat bar.as your tacking and shaping small taps with a body hammer helps get it into place.then repeat with the other side.
9th step.... tack weld both seams on each side every 2 inches apart until its all welded.dont let it get too hot or it will warp.once done use a flap disc to buff and round the edges.
10th step...install it in place and carefully drill holes where you want to mount it to the floor .i welded 1/4 thick flat bar tabs drilled and tapped to thread a 1/4 bolt into.worked great.but im sure sheet metal screws would do also
11th...cut holes for gauges/shifters/switches/nitrous bottles/cup holders ect then body fill/prime/paint and enjoy
and to be honest once your into it its not that hard at all.
hope this helps
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 12-04-2011, 11:53 AM   #281
darkgable79
Thanks. It seems simple enough. I've never welded before, but I'm taking your advice from an earlier response. You said just buy a cheap mig welder and go after it. So I'm gonna do just that. Thanks again and good luck with the rest of the build.
Old 01-05-2012, 08:15 PM   #282
VeronikA
VeronikA's Avatar
Hey Joey! Great project homie! Keep up the hard work! You did a sick job in the interior! Looks really awesome! And I've been always a big fan of flat black! Thumbs up for you buddy!!!!
VeronikA is offline   Reply With Quote
Old 01-07-2012, 02:01 AM   #283
68 TT
Still plays with trucks
68 TT's Avatar
Great project. You have done a mountain of work in a pretty short period of time. It won't be long now.
I am doing a similar color combo with my stepside. Satin black with a maroon interior.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 01-07-2012, 04:27 AM   #284
orngsikL
orngsikL's Avatar
very cool build.
and yes, the abs has to bled with a tech2. might be able to use hp tuners or efi live, never tried...
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 01-07-2012, 10:17 PM   #285
slick copper
Hey! I know how things go, but any progress?
Raymond
Old 01-08-2012, 05:03 PM   #286
(joey)
(joey)'s Avatar
it was a ton of work in a short time.but it made for a great winter.that color combo should be great.i find it really makes the red pop out
Old 01-08-2012, 05:05 PM   #287
(joey)
(joey)'s Avatar
thanks man.i gave up on the abs and im going with a wilwood dual resivoir system.its simple and looks hella cool.
Originally Posted by orngsikL View Post
very cool build.
Old 01-08-2012, 05:06 PM   #288
(joey)
(joey)'s Avatar
thanks gurlie.i think i remember you saying somthing about flat black in your build.im going to send you a private message with some info
Old 01-08-2012, 05:14 PM   #289
(joey)
(joey)'s Avatar
beleive it or not i do have a little progress.it was warm enough today that i could actually do something and not have my jewls freeze off.a little while ago when adjusting my door i slammed it hard one time and the factory rivit broke through the lock/door handle mech.i took it out and welded a washer on the pin to keep it place.anyways i got it installed back in place today.also started the ol girl up and let it run for a bit.and i forgot to update a while ago when i discovered that the door rubber off of my 2001 cab will fit on our trucks great.all i had to do was trim off about 5 inches or so where the two seams met.it literally took me less then 5 mins to remove and install.it feels alot softer then the new after market rubbers i had installed in the summer.not exciting updates but still an update.work should slow down soon so i should be back full force soon.
Old 01-08-2012, 07:37 PM   #290
68 TT
68 TT's Avatar
Good to hear the newer seals fit. Should be a better design.
Old 01-08-2012, 08:25 PM   #291
slick copper
That's cool about the door seal actually. Time to scour the junkyards! Yeah, it's been a pretty warm winter so far here in KY. I've been out some, but been working on my Tundra and other things. Neglecting the 67 lately. Shhhh!
Raymond
Old 01-21-2012, 08:25 AM   #292
(joey)
(joey)'s Avatar
i was quite impressed how easy they fit into place.after sitting for a few weeks with the door shut i went out yesterday to get some tools from the cab and i noticed when i shut the door it was even more easier then before.i might try a little heat and work in when its pinching a little tight.got an extra bed room in KY?my truck should be showing up in your garage in a day or two good buddy hahaha.on a side note i have the box sides so close to being ready for paint.after leaving them for a while and getting back at them i found a couple high spots i had to knock down.good to be back at her
Old 01-21-2012, 08:28 AM   #293
(joey)
(joey)'s Avatar
forgot to ask.i got a question for you guys.im going to buy a steering wheel soon.because its going to be after market im going to need an adapter.do any of you guys know which adapter i will need for the 2001 steering column?
Old 01-21-2012, 11:58 AM   #294
kev2809
low n' slo
kev2809's Avatar
hey, i was flipping back through your build and i didnt see what paint you used for the interior...
ive got mine sanded down and was about to head down to the tractor supply and pick up the red they have, its single stage (same paint i used on my firewall).
thanks!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-21-2012, 06:20 PM   #295
(joey)
(joey)'s Avatar
thanks!
i forgot to write what it was.it was a cheaper single stage that dupont made.forget the name of it but it covered great
Old 01-21-2012, 07:16 PM   #296
kev2809
low n' slo
kev2809's Avatar
ya it looks good man...did you get any imperfections in it?
when i shot my single stage tractor paint i got little dots everywhere..wasnt sure if it was the paint or the fact im not running a dryer or anything (just a small filter at the gun)
-_--_--_ _________
Old 01-21-2012, 08:52 PM   #297
(joey)
(joey)'s Avatar
i got a small amount of dust in mine.sounds like you got fish eyes.could be a contaminated surface.oil,silicone from Armour all ect.may have to let it dry,wipe it down with degreaser,sand it,wipe it down with degreaser real good again and spray it again
Old 01-21-2012, 09:41 PM   #298
kev2809
low n' slo
kev2809's Avatar
ya..thats what ive been told. i actually did sand it down, even filled the small pinholes with filler, resanded, and resprayed. same thing happened just not as much and not as worse. sucks but im leaving it lol
did you run a dryer on your compressor?
-_--_--_ _________
Old 01-22-2012, 05:42 AM   #299
slick copper
Wish I had my garage so you could come down with it!
As far as the steering wheel, I'm pretty sure most chevy's have the same spline there's a few different ones, but camaro wheels fit our stock columns. Here's a thread that talks about some different steering wheels. One guys says 88-up are the same. Maybe this'll help ya out some.http://67-72chevytrucks.com/vboard/s...steering+wheel
Raymond
Old 01-27-2012, 08:22 PM   #300
(joey)
(joey)'s Avatar
i dont think it has a dryer.its my buddy's garage so im not sure.never noticed.too bad you got them again.decide on a 3rd try yet or still leaving it?
