Closed Thread
Old 12-04-2011, 02:05 PM   #4326
Oldgearz
Oldgearz's Avatar
Re: What did you do to your truck today?
I pulled a 305 v8 from my 55 chevy parts truck and made the decision to rebuild it as a hi perf engine w/700 r4, and put it in my 62. Now I need to figure out if I should sell the 305 v6 w/muncie 3 spd from my gmc. Any ideas on how much it's worth? runs good but leaks a little from the pan & tranny is good. Or if anyone local is interested pm me
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto!
Oldgearz is offline
Old 12-04-2011, 05:18 PM   #4327
tincan1966
tincan1966's Avatar
Thumbs up Re: What did you do to your truck today?
Originally Posted by Rich 5150 69 View Post
If you chose a fixed idler gear drive like the sig erson, quiet one they sound a little better, pete jackson dual idler drives are notorious for some reason for he growling, even though I chose a quiet gear drive for my coupe, after several long road trips it sorta made me nuts......
Yeah I went the dual idler route and regretting it, but at least it's not a major teardown to fix. This is by far the worse one I have ever heard and I checked the spacing 4 times before sealing it all up. Got the old reliable double roller on order, will be here Tuesday. Thanks for the info tho, something I will remember.
tincan1966 is offline
Old 12-04-2011, 05:23 PM   #4328
Hilandr451
Hilandr451's Avatar
Moved all our stuff down to Bakersfield from Vacaville.
New shop:
The cab is on the side of our new house ready for the new shop! I can't wait to get back into the resto!!!
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline
Old 12-04-2011, 10:02 PM   #4329
E911manager
Meshed the caprice and 64 core support together. Mounted the radiator, AC condenser and the oil and trans cooler. Hung the sheet metal on it to see what was rubbing and/or in a bind. So far so good.. Everything is tacked in place. Now, time to take it all apart and start boxing the frame back in and making it more permanent..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 12-05-2011, 03:11 AM   #4330
KroAutomotiveInc
KroAutomotiveInc's Avatar
set my headlights up today on relays
http://67-72chevytrucks.com/vboard/s...elay+headlight
KroAutomotiveInc is offline
Old 12-07-2011, 02:49 AM   #4331
C4 Metal Werks
C4 Metal Werks's Avatar
After 6 weeks of cleaning, tuning and replacing parts I was able to to a 150 drive today.
I love driving it!!!!!!!
C4 Metal Werks is offline
Old 12-07-2011, 06:45 AM   #4332
KroAutomotiveInc
set up dual high and low pitch horns with a relay
Old 12-07-2011, 11:44 AM   #4333
1963c-10
1963c-10's Avatar
Banged my head on the wall over a blown intake gasket...arg
1964 Short bed trailer
1963c-10 is offline
Old 12-07-2011, 12:21 PM   #4334
Clyde65
Clyde65's Avatar
My LS swap started with that, then found a cracked head, figured the LS was the way to go.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 12-08-2011, 11:09 AM   #4335
tincan1966
tincan1966's Avatar
Took a couple days vacation to make a long weekend to clean up the shop from the '69 rebuild and getting that "Burb back in to work on front suspension. Also going to mock up console/shifter idea and start to lay out some of the wiring. I have 3 harness to merge,- the EFI harness, the chassis harnes and the Phantom Key harness. Thank God they are all Painless Wiring parts. will post some pics later of some of the fab that is going on. Have a great weekend everyone!
Old 12-08-2011, 04:27 PM   #4336
markeb01
Senior Enthusiast
markeb01's Avatar
It must be a personal preference thing, or perhaps they are louder now than those produced many years ago. I’ve been running a Pete Jackson noisy drive since 1991 and can’t imagine doing without it. I had a Summers Brothers drive before the Jackson, and although it was an engineering work of art it was too quiet for my tastes. For me the gear drive is just part of the fun factor which includes a Richmond 4 speed, suitcase mufflers and no insulation. There are so many mechanical sound effects to enjoy I eliminated the radio years ago.
You must not be alone in your annoyance with gear drives. Back in the 70’s-80’s it seemed like everyone had one. Where I live now I think I’ve heard maybe one or two others in the last 10 years so they have apparently fallen out of favor.
markeb01 is offline
Old 12-08-2011, 05:30 PM   #4337
tincan1966
tincan1966's Avatar
I actually took the cheap route, something I don't normally do and bought a no name gear drive. Fixed the problem already and still have the drive- had to relieve the main idler boss where it contacts the block-found my problem was misalignment under load. it's much better now and I kinda like it!
Old 12-09-2011, 09:09 PM   #4338
198plus
198plus's Avatar
Painted my bed today......
198plus is offline
Old 12-09-2011, 09:28 PM   #4339
northern 85
northern 85's Avatar
Nice shine!!!
northern 85 is offline
Old 12-09-2011, 09:30 PM   #4340
Rich 5150 69
Rich 5150 69's Avatar
Still like the gear drive although on long road trips makes me nuts, actually had one young kid ( no pun intended) at our local cruise that drives a new camaro asked me what was wrong with my trans that was making it whine....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 12-09-2011, 10:01 PM   #4341
64shortbox
64shortbox's Avatar
198plus,
Fantastic job!!!! And Black too, those panels have to be lazer straight to pull off a gloss black paint job. I know yo have lots of man hours in those 2 bed panels. Again Great job!!!!
64shortbox is offline
Old 12-09-2011, 10:10 PM   #4342
SCOTI
SCOTI's Avatar
....actually had one young kid ( no pun intended) at our local cruise that drives a new camaro asked me what was wrong with my trans that was making it whine....
That's funny right there! They know everything right??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 12-09-2011, 10:10 PM   #4343
SCOTI
SCOTI's Avatar
Oooooooooooooooooooo . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 12-09-2011, 11:18 PM   #4344
64shortbox
64shortbox's Avatar
Finished the installation of a van tilt in my 64. I'm lazy and took the easy way out. I drilled a 3/8" hole in the center of dash where the column mounts, dropped in a 3/8" - 24 X 3/4" bolt backed it up with a 3/8" - 24 jamb nut which happens to be 1/4" thick, I then cut a piece of 1/4" rubber to install between the column and the dash. I pushed the column as close to the dash as I could and drilled a 3/8" locating hole in the top of my column to fit my centering bolt. Using the factory column mount holds plenty of pressure to keep the steering column tight in the truck.
Old 12-09-2011, 11:29 PM   #4345
198plus
198plus's Avatar
Nice job, I like that column......What year van did it come out of ???
198plus is offline
Old 12-09-2011, 11:29 PM   #4346
markeb01
Senior Enthusiast
markeb01's Avatar
I had a co-manager ask me the same thing back in the 1980's. Another enthusiast and I were discussing gear drives when the manager came in and condescendingly asked "is that the thing that makes it sound like your transmission is going out"? I responded - "only to the uneducated"!
markeb01 is offline
Old 12-09-2011, 11:32 PM   #4347
markeb01
Senior Enthusiast
markeb01's Avatar
This is incredibly beautiful. I can't wait to see the whole truck painted and back together. Excellent!! Am I correct in assuming you also filled all the seams?
markeb01 is offline
Old 12-10-2011, 12:02 AM   #4348
198plus
198plus's Avatar
Originally Posted by northern 85 View Post
Nice shine!!!
Thanks, they did turn out lazer straight.
198plus,
Thanks, I said the same thing......lol
Thanks.......I can't wait either, it want be long. We filled all the seams but the hood.
198plus is offline
Old 12-10-2011, 12:14 AM   #4349
64shortbox
64shortbox's Avatar
Added 4 Way Flashers to my 64. Since I installed a 70's Van Tilt and the column had the provision for Emergency Flashers I wanted to make them work. I cut the flasher connector out of a 72 Nova in the wrecking yard. One side of the connector gets power from a constant HOT off the fuse block. The other lead runs to the "K" terminal (a brown wire) on the factory GM column connector. I read that you should use a 15 Amp fuse so I ran #14 wire. For my constant HOT I picked it off the Spot Light terminal of my fuse block and poped in a 15 Amp fuse. You don't have a "Spot Light" terminal on your fuse box? No problem, neither did I. In the wrecking yard locate a 60-66 truck fuse block, remove the Heater/B.U. Lamp fuse, take out the 1/4" head screw holding the fuse block in place and the screw in the Spot Light fuse location. Remove the fuses from the Brake LP & BU LP locations. From the back side of the fuse block - using a small flat blade screw driver release the tangs that hold the fuse clip in place and push out the front of the fuse block. The fuse clip I show in the middle of the first 2 pictures is the wrong clip it's for reference only. That clip is form the Panel LTS fuse and is the wrong one. You must use the clip from either the Brake LP or BU LPS fuse.
Old 12-10-2011, 12:21 AM   #4350
64shortbox
64shortbox's Avatar
I bought the column off eBay so I'm not 100% sure what year it is but I think the seller said it was a from a 71 van. I was the only bidder at $99.00 plus $19 shipping. I don't think I did too bad on the price of the column.
Closed Thread
