How to remove 66 deluxe steering wheel
How do I remove the horn ring off wheel. I pulled hard but still not coming off. I don't want to crack it. Thanks for any help.
Posted via Mobile Device Posted via Mobile Device |
![]() Join Date: Apr 2011
Re: How to remove 66 deluxe steering wheel
On my 63 there are small screws behind the spokes on the wheel that hold the ring in place. Not sure if 66's are that way but have a look behind the wheel and there should be 5/16 or 1/4 hex head screws.
You need to use a steering wheel removal tool. You can find these at just about any parts store from $15.00 to $100.00. Kragen's & O'Rileys will usually let you borrow one for free providing you pay the cost of the tool as a returnable deposit up front. again, that is usually around $15.00.
Here's a how-to page I put together to do exactly what you're trying to do:http://www.64moneypit.pages.qpg.com/...cks/id108.html
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
El minero- I dont see any screws.
Hilandr451-very nice write up. i got puller for wheel. I don't know how to remove horn ring. I think it's just pressed in there on a rubber sleeve , but I'm not sure. How hard do I pull/pry on horn ring.??? Posted via Mobile Device |
![]() Join Date: Oct 2009
jack - you must pry (usually can do it by hand) the center cap off - then you'll see the 3 screws. Hard to tell the cap is removeable, but it is.
The very center of the horn ring pops out and there is a single nut that holds the steering wheel to the shaft, and 3 screws holding the horn ring. The picture below shows the main nut removed as I was going back together with the whole mess.
![]() Make sure you don't loose this: ![]() Or this: ![]() After removing these items, you will find the threaded bolt holes to attach your puller to: ![]() Make sure to remove the horn actuator button and the little spring inside before you pull the steering wheel off.
Easy Does It
if its a deluxe model then you need to unscrew the 2 small screws on the backside of the wheel -you will see holes behind each spoke,one on each side, then it falls off
the wheel pictured above by hilandr is a deluxe (for 66) - so should be nothing more than prying off the center, then removing the 3 screws. Brawley - are you referring to a 65 & prior deluxe wheel? If so, I did not know that about them, thanks. I believe the 2 screws you are referring to are for prior years - what you described is the same attachment method for early 60's full size cars as well (i.e. 2 screws from behind wheel).
![]() Join Date: Feb 2010
If you think theres a black rubber ring under it, then just pull it up with your hands. There are 3 types. One is like Hilandr451 shows. Another is like brawley said, with screws in from the back side. The 3rd is like i said. The rubber ring should come out with the cap. I dont have any pics, my stuff is packed away. Post up a pic of yours.
the horn will pull off,,it is usually a job for a 3 handed man ,,,just pull hard while having a screwdriver popped in the back prying at the same time,,,,then once all the cups and screws are undone,,,,and the 3/4 nut removed,,,most times you can rethread the nut most of the way back on to protect the threads and hit it really hard with a 20lb hammer while pulling the the steering wheel,,,this will usually pop most steering wheels off ,,,even those which have never been removed before,,if this does not work you will need to get a puller,,but they can be really hard on the plastic part of the wheel,,,just be carefull,,,but usually the bang and pull method works just fine,,,
I gave up yesterday. Will get a 3rd hand today. I
Have seen broken off 66 deluxe wheel horn rings and now I know why. Thanks for all the help. Posted via Mobile Device |
#12 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#13 | |
I mean no disrespect to our Paphigliano, but I would highly recommend the $15.00 steering wheel puller over the "pop & pull" method. Trust me from personal experience, it is very easy to mushroom out the fine threaded steering shaft, even with the nut in place and pulling on the wheel while your buddy smacks the shaft with a 20lb sledge can be dangeruth to thay the leatht.
#15 |
hi. first of all i got to stop drinking beer when im working on the truck! hilandr was correct. the center cap comes off.. thanks to all.
#16 |
SO, to remove "HORN CAP", (not steering wheel)......
To remove "HORN CAP" on a 1966 Chevy C10,...you are all suggesting that it needs to be "pried off" ? I dont want to crack my Horn Cap..........it doesnt seen to want to snap out. Any more suggestion...? |
#17 | |
It's Better With Nitro
This steering wheel, correct? ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#18 |
Thank You Vin63!
#19 | |
Thank You Vin63!
And yes it's the same exact steering wheel in your post, except I have a 3 In A Tree Column Shift. ![]() Quote:
#20 | |
