Moderator
![]() Join Date: May 2007
Here is a very nice gauge cluster that I restored. I used excellent OEM gauges, and repainted and clear-coated the needles. The tachometer is brand new, as well as new correct inner/outer tins, new lens, new chrome bezel, and a new circuit board. Pics speak for themselves. I will also include a new tach harness with this set-up. Bolt in and go. New tach clusters sell for $550+ from vendors, get a deal here.
$400 Shipped, tracked, and insured in the CONUS.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Moderator
Re: New/Restored Tach dash for sale
pics
VA72C10
![]() Join Date: Mar 2008
Nice work! All the gauges look good including the usually faded temp
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Just a Member
WOW!!! I will be dealing with these bad mamma-jammas one day... GREAT WORK!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
Will that tach and harness work with hei ignition?
Moderator
Yes, it will work with hei...I have the same setup on my 402. The only thing you have to do is swap the horseshoe connector on the harness for a spade connector so it will plug into the hei cap...however if you are using hei with an external coil the horseshoe connector will work.
Moderator
Black Friday Bump. Open to reasonable offers...
Moderator
Sold to BBC Motorhead. Thanks Mike!
Got it tonight. It looks great! Thanks
