Old 12-07-2011, 07:17 PM   #626
superflysteiny
superflysteiny's Avatar
Re: 66 DiBella (means of the beautiful)
Originally Posted by 67cheby View Post
well i hope whoever bought it does it justice !!
I hope so
superflysteiny is offline   Reply With Quote
Old 12-07-2011, 07:19 PM   #627
superflysteiny
Originally Posted by Nobaddaze View Post
bummer its gone, but that means you have room for a new project right?
thats right
Old 12-07-2011, 07:20 PM   #628
superflysteiny
Originally Posted by keets36 View Post
anyone on this forum buy it ? hopefully so we can see it finshed!
The person that bought it just uses the forum to get ideas but is not a member from what I understand.
Old 12-07-2011, 07:34 PM   #629
R.A.D
did you make out on this one?
R.A.D is offline   Reply With Quote
Old 12-07-2011, 07:35 PM   #630
superflysteiny
ya I did just fine
Old 12-07-2011, 07:36 PM   #631
R.A.D
so whats next is it the ford or...........
Old 12-07-2011, 07:39 PM   #632
kev2809
low n' slo
kev2809's Avatar
a burban!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-07-2011, 11:29 PM   #633
superflysteiny
Ya that's the plan need a family truck
Old 12-07-2011, 11:35 PM   #634
mcbassin
Still Learning
mcbassin's Avatar
Build thread? pics?........ looking forward.
Old 12-08-2011, 02:28 AM   #635
superflysteiny
Coming soon my man
Old 12-08-2011, 07:28 AM   #636
R.A.D
a burben. well lets roll........... can't wait
Old 12-08-2011, 11:20 AM   #637
superflysteiny
Getting ready
Old 12-09-2011, 03:14 AM   #638
luis979motoring
luis979motoring's Avatar
sad to see it go, this truck is the first one of your builds that I saw and fell in love with your craftsmanship and ingenuity. looking forward to whats to come from your next build! seatbelt on and ready for the ride!
luis979motoring is offline   Reply With Quote
Old 12-09-2011, 08:20 AM   #639
racedaddy
racedaddy's Avatar
Thumbs up Re: 66 DiBella (means of the beautiful)
Getting ready
So I guess we'll see it this weekend?
66 Chevy 305 /350 auto, bagged, custom frame
racedaddy is offline   Reply With Quote
Old 12-10-2011, 12:54 AM   #640
superflysteiny
No so fast. I really am trying
Old 09-01-2012, 01:17 PM   #641
zippeay
zippeay's Avatar
When you lowered the front of the frame horns did you run into any problems by cuttin it behind the lower radiator support? I'm trying to figure that out on mine right now but I noticed most people cut in front of it. I tore my truck apart over a year ago and I don't remember how everything goes together. I would appreciate any help. Thanks!
zippeay is offline   Reply With Quote
Old 09-04-2012, 11:11 AM   #642
superflysteiny
You have to cut in front of the support. If I were you before you z the frame I would consider a drop member. I no it cost more money but in the end it will save you a ton of head ache. Zing the frame is not hard but you will have to run a narrower radiator because it will have to fit between the frame rails
Old 09-04-2012, 12:21 PM   #643
zippeay
zippeay's Avatar
Well... I've already done 99% of the work to do it this way. I will post pictures when I get home of how I did mine. I ended up cutting in front of the support and lowering the whole Radiator support. Hopefully I won't run into too many problems. I didn't want to use a custom radiator. Hopefully I didn't screw myself but I'm fairly sure that I can fix or work around whatever I did. I will post a picture and hopefully someone can point out if I need to change anything. I appreciate the advice but I've already Z'd the frame and pancaked my crossmember and cupped the LCAs plus I don't have the cash for the crossmember, I know they are nice and honestly if I had to do it all over again I would probably buy one but it's too late now.
Old 09-04-2012, 12:40 PM   #644
superflysteiny
ok cool no problem I hope I can help
Old 09-04-2012, 02:28 PM   #645
zippeay
zippeay's Avatar
Here are the pictures. I still have to finish it up but this is what I came up with. I know I will have to move the steering box a little forward but when I did my Z I moved everything up an inch so that shouldn't be too much of an issue. Basically I cut right in front of the support and lowered the radiator support down. Then I made some pieces for the bottom in order to keep the crossmember in one piece. Hopefully this all works out all right.
Old 09-04-2012, 02:33 PM   #646
superflysteiny
The tanks on the rad will hit the frame I am sure it will not fit. I would just buy an new radiator that is narrow. I can get you one from american past times for about 180
Old 09-04-2012, 02:45 PM   #647
zippeay
zippeay's Avatar
Ok thanks for the advice! I will try and see if I can make this work if not I will let you know about the radiator. Thank you so much!
Old 09-04-2012, 05:39 PM   #648
superflysteiny
No problem anytime. Just pm because I dont check this thread to often. I sold this truck
