Old 12-10-2011, 12:56 PM   #1
jeff r
Re: Need Help with a vibration in my Jimmy
I jacked up the jimmy this morning and pulled on the tire and the axle has play. I can pulled it out and push it in. (very little movement but some) the movement is not really a wobble the axle just has play in and out. I can't shake the tire just pull it in and out and little movement up and down not side to side. The other side has no movement or play. I'll jack it up and try it.
Jeff
jeff r is offline   Reply With Quote
Old 12-10-2011, 06:07 PM   #2
jeff r
Thanks Mike
It was a tire/rim issue. I rotation the tires and problem moved to the front. I'm getting my Jimmy set-up. I'm going to post some pics when I finish in a couple of weeks.
Jeff
