Old 12-09-2011, 11:11 PM   #1
blkcorvair
blkcorvair's Avatar
Is there a Factory harness for my Gauge Cluster Lights?
So I have the base of all base model trucks. (69) I have three gauges. (None which light up. Also my heater does not light up. It looks like all of the provisions are there for the factory to simply plug a new harness into the fuse box and instyall these lights. Is such a factory harness out there? and if so does someone reproduce it?
Thanks!
blkcorvair is offline   Reply With Quote
Old 12-10-2011, 01:55 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Is there a Factory harness for my Gauge Cluster Lights?
There is only one wire from the fuse box to the cluster plug for the dash lights. It's a gray 20 gauge wire that runs from the back side of the pnl lts fuse to the cluster plug to terminal 12.
fuse panel gray wire
Name:  Copy of Cab-1web panel lights.jpg
to cluster plug.
Name:  Copy of Cab-2-web PANEL LIGHTS 2.jpg
Check for power on the panel lites fuse and for an open wire from the fuse panel to the cluster plug at pin 12 gray wire. Then make sure the cluster is well grounded.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-10-2011, 06:49 AM   #3
cdowns
cdowns's Avatar
have you checked to see if there are lightbulbs in the lightbulb holders?
have you tried new lightbulbs?
Old 12-10-2011, 02:14 PM   #4
blkcorvair
blkcorvair's Avatar
I dont have light bulbs, holders or a harness. was never there to begin with. There are holes in the back of everything for the "upgrade" but seems to have come stock without it.
Its not that it doesnt work, My truck just never had them to begin with. Id like to add them, but didnt know if there was a factory harness I could get with all the bulb sockets that plugs right into the fuse panel.
Old 12-10-2011, 02:29 PM   #5
john
member #16
john's Avatar
All you need are the bulbs and sockets. There is a printed circuit on the back of the cluster.
john is offline   Reply With Quote
Old 12-10-2011, 03:24 PM   #6
blkcorvair
blkcorvair's Avatar
Very cool. Im going to look at this now.
Old 12-10-2011, 03:29 PM   #7
blkcorvair
blkcorvair's Avatar
Okay now I feel really stupid! Never looked close enuf to realize those little black plugs are bulb sockets!!! and or course the cluster lights were akll blown. Thank you for teaching me something new!
