Old 12-10-2011, 02:42 PM   #1
83highsierra
83highsierra's Avatar
new truck
Ok quick question I just recently aquired an 84 4wd was told ran great....... A year and a half ago. I haven't stried to start yet. So where do I start. I was going to put heet and stabil in tank. I've never bought a vehicle that sat so long. I kno front brakes are siezed. So i will take that apart. Owner told me his son rebuilt trans awhile ago but forgot to put a pan seal so no fluid. I believe its stuck in 4wd cause I put the 4wd shifter in N and put back tires on tow dolly and the front tires slid and wouldn't rotate but when flat it rolled when i pulled it to side. Any advice would be great
83highsierra is offline   Reply With Quote
Old 12-10-2011, 07:55 PM   #2
83highsierra
Re: new truck
Anybody I didn't WANt to try and start it and ruin something
Old 12-10-2011, 08:45 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: new truck
Last one I did that had sat for a few years, I just removed the spark plugs (inspect and replace if needed) and put a little marvel mystery oil in the holes and let it sit. This let a little lubrication go down and loosen everything up. I poured some fresh gas in the carb after putting additives in the gas tank along with a few fresh gallons of gas. Fired right up with a new battery after that.
There was a pretty good article somewhere about what to do in this situation, maybe in the engine section here is where I seen it.
http://67-72chevytrucks.com/vboard/s...d.php?t=384395
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 12-11-2011, 08:08 AM   #4
83highsierra
Re: new truck
What do u think about trans and transfer case in gonna pull pan to see if theirs a gasket but if no fluid in trans would transfer case lock itsself in 4wd
