Old 12-11-2011, 01:42 AM   #1
69vetteside
69vetteside's Avatar
puzzled on the front suspension
guys,since buying my 69 i have read and reread all the threads concerning drop spindles.as well as looking up pics from vendors on the site.
what i am noticing is that the pics that contain both sides ,the spindle is at different hieghts,i assume this is the way it goes on the truck.I was told by some guys on the site that my spindles should be more to the top of the arm if they are indeed drop spindles but mine seem lower on both sides. now also from what i have read drop spindles are to have disc brake conversion which mine has and the lower tube A arm.
Is there a measurment on the spindle i can make to check if they are stock or drop spindles ?
I dont want to order a set and find out i alredy have them on specially since i have to import them to australia.
any help much appreciated
69vetteside is offline   Reply With Quote
Old 12-11-2011, 04:08 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: puzzled on the front suspension
Can you post a picture of your spindles?
It's very easy to tell.
Keith
Convert to disc brakes.
Old 12-12-2011, 04:54 AM   #3
69vetteside
do you want a pic from the back i am assuming.I will do it tomorrow.
thanks
Old 12-12-2011, 06:43 AM   #4
lolife99
lolife99's Avatar
thanks
Yes,... from the back side.
The drop spindle is on the right in this picture.
Keith
Old 12-12-2011, 08:39 AM   #5
69vetteside
ok, so mine are both like the one on the left. is this how they are at stock height spindle ?
Old 12-12-2011, 08:54 AM   #6
lolife99
lolife99's Avatar
Yes.
Keith
Old 12-12-2011, 02:23 PM   #7
jimmydean
jimmydean's Avatar
The "dropped" spindle on the right is raised in the spindle casting and is what they mean by a dropped spindle.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-12-2011, 02:37 PM   #8
chevyrestoguy
chevyrestoguy's Avatar
Oftentimes, another dead giveaway is that many drop spindles have the manufacturers name cast into the spindle. You'll also find that that the drop spindles are whole lot more beefier than a stock spindle, as Keith's picture shows perfectly.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-13-2011, 06:27 PM   #9
tubbedII
needs more $$$
tubbedII's Avatar
Everyone has you covered on the drop spindle, but you mentioned you have lower tube arms. I've always heard you don't want to run a combination of "Drop Arms" and Drop Spindle as it will put the recessed part control arm too low and in danger of hanging up. When you take the pics, get one of the lower control arm as well so we can see.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
