12-11-2011, 06:10 AM | #1 |
drop spindles, and disk brakes....
I am bagging my 60 c10. My plan was to box the lower control arms, and pull the torsion bars. I'm about to buy drop spindles, but from what I can find I need to swap crossmembers, and suspension to a newer truck. I want to keep the 6 lug, and brake swap to disk shouldn't be a problem, but can I keep the stock arms? Will the torsion arm ball joints work with the drop spindles? I don't really want to have to change crossmembers, and arms, as I'm doing this on a budget.
Posted via Mobile Device |
12-11-2011, 07:47 AM | #2 |
Re: drop spindles, and disk brakes....
hope you know that the original 6lug steel wheels from 1960 normally wont work with disc brakes
12-11-2011, 07:49 AM | #3 |
I have a set of centerline 20s I'm going to run
12-11-2011, 05:28 PM | #4 | |
67-72 parts collector,…
They sell a 60-62 drop spindle for $229.00. http://www.performanceonline.com/196...dle-Set-16683/ And a disc rotor that is drilled to the 6-lug pattern. http://www.performanceonline.com/FRO...10-TRUCK-8600/
12-11-2011, 07:31 PM | #5 |
A guy with a truck
POL 15% off- coupon code CM11...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
