Old 08-26-2003, 04:05 PM   #1
GMC 3
how to change front seal- th350?
have the tranny out of the truck and want to change front seal before I put in in my truck. How do I remove the seal and what is best way to put in new seal? thanks
GMC 3 is offline   Reply With Quote
Old 08-26-2003, 04:11 PM   #2
COBALT
COBALT's Avatar
Piece o' cake. Use either a seal puller or a hooked slide hammer to yank that seal out of its bore from the center of the seal outwards. You don't want to dig next to it, and tear up the inside of the bore.
Once you get it out (it'll take a little bit) you can either use a seal driver made for the front seal (you can get them from Atec Trans-Tool or Kent Moore), or just carefully tap it in working around in a circle with a plastic or rubber hammer. Don't warp the seal body. It needs to go in straight and flush with the pump body.
You might want to replace the rear seal as well so they're both the same age. Remember to put a little vaseline on the seals before putting the converter and slip yoke back in.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-26-2003, 04:20 PM   #3
crazy longhorn
Fabricate till you "puke"
Im a "cheap"player.....you can drive a screwdriver in the "front tin " on the seal & pop it out.....be carefull as Cobalt has suggested, not to scar the pump housing. I use a short lenght of the proper sized pipe to drive the seal back in. yes, & a little lube on the seal lips.....a dry seal will fail. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-28-2003, 04:45 AM   #4
OhioDan
OhioDan's Avatar
I made a seal driver for that using a piece of exhaust pipe, and an old bearing race. Locate a race that will cover the new seal completely, and weld it onto a piece of exhaust pipe, wide flat side to the seal. Workie goodie. AND CHEAP ALSO!
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
