Old 12-12-2011, 12:11 AM   #1
BlueJeep
BlueJeep's Avatar
Vintage Air condenser for AD
Anyone have a picture of a Vintage Air condenser mounted in an AD? I'm trying to figure out if the one that comes in the SureFit kit will fit my modified radiator support in my s10 swapped AD. Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-12-2011, 06:25 AM   #2
coralhead
coralhead's Avatar
Re: Vintage Air condenser for AD
Sorry for the picture bad quality....I have one on my '50 that I am building.
I had to rebend the upper mount brackets to accomodate for moving the radiator forward for the '59 235.
coralhead is offline   Reply With Quote
Old 12-12-2011, 09:02 PM   #3
Kid
Kid's Avatar
Not sure what size condensor your 'sure fit' has, but I think the bigger, the better when dealing with R-134 freon. Here's how I mounted mine. This method allows radiator removal without disturbing the condensor.
Kid is offline   Reply With Quote
Old 12-12-2011, 11:52 PM   #4
BlueJeep
BlueJeep's Avatar
Thanks, is that the one that comes with the SureFit kit? Did you use their under dash vent assembly?
I'm not sure what size comes with it either, I'm looking for a starting point. I have a chopped up radiator support, much like yours to accommodate my s10 frame and steering box. I have a 5.3 and I'm looking at the Sandin compressor relocation brackets to put it up high on the passenger side. Are you using the stock 5.3 compressor or a Sandin one? Did you just pick the biggest condenser you could fit there and then make the lines yourself or have them made? I like your style in mounting the condenser, I'll likely do something very similar. I have to move my tranny cooler anyway.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-13-2011, 10:29 AM   #5
youngrodder
youngrodder's Avatar
I have a vintage air set up but I bought my condenser off of Ebay.
I just build little brackets simular to Kids approach.
I mounted the dryer on the passenger side frame rail up front. I still need to finish running that hose before I can get my system charged.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-13-2011, 09:17 PM   #6
Kid
Kid's Avatar
I used the stock compressor & the largest horizontal condensor vintage air has, got lucky that it hides the aluminum radiator. Really didn't want the shiny radiator visable behind the grill.
Old 12-13-2011, 10:42 PM   #7
BlueJeep
BlueJeep's Avatar
Are there any performance issues with the stock compressor? I was under the impression that the V/A system would under-perform when using a stock compressor, but I'm not sure how reliable my source was for that.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-14-2011, 09:09 PM   #8
Kid
Kid's Avatar
my compressor came out of a 2004 pickup. It has worked great since 2007. I don't think the trucks used a V/A type compressor.
