Old 12-10-2011, 08:38 PM   #1
wyo tim
wyo tim's Avatar
Smile Snow from defrost vent
hey does anyone have a fix for the "start your truck in the morning and snow blows out the vent and causes a bizzard inside the truck Problem"
72 Chevy K20 NV 4500 /dana 60 /gm 14bt
72 GMC K10 Super Custom
84 GMC K35 SRW 454 t400/205
03 Ram 2500 w/Cummins
wyo tim is offline   Reply With Quote
Old 12-10-2011, 08:47 PM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Snow from defrost vent
hhhhmmmm Can't say that I do.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 12-10-2011, 09:02 PM   #3
wyo tim
wyo tim's Avatar
I'm guessing from your location you might not see much snow.
Old 12-10-2011, 09:03 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Maybe move to Florida???
I've heard of those blizzards but never been in one.
68gmsee is offline   Reply With Quote
Old 12-10-2011, 09:58 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
We use a inline heater that mounts on lower heater hose (next to the water pump inlet) on our community snow plow. Works good, get in and your ready to go!
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-10-2011, 10:15 PM   #6
1972RedNeck
1972RedNeck's Avatar
I brush my cowl off before I start mine. It works. A block heater will get it up to temperature faster too.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-11-2011, 08:39 AM   #7
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
The cowl on our trucks is a huge snow trap. You could lay a blanket across the cowl grate until the truck warms up enough.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-11-2011, 07:00 PM   #8
wyo tim
wyo tim's Avatar
I was hoping someone might have built a defection shield or some kind of widget to keep it from just pulling the snow in. Even if you sweep the snow off before you turn the defrost on there is allway some that blows in and the extra moisture fogs up the windows. Man what a bummer.
Old 12-11-2011, 08:07 PM   #9
463
463's Avatar
some have put window screen under the cowl to help with snow and leaves entering the area.
Trueman
463 is offline   Reply With Quote
Old 12-12-2011, 11:42 AM   #10
RenoKeene
Florida Edition
RenoKeene's Avatar
My 70 GMC factory a/c truck has this flap vent in the cowel operated by a vacuum canister on the firewall. This would keep the snow out...if we had such a thing down here.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-12-2011, 12:39 PM   #11
shawno72
C/10 junkie
shawno72's Avatar
What I would is charge admission to the interior of your truck and make a slide out each side for kids to go tubeing. Extra Christmas money.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-12-2011, 02:37 PM   #12
Husker
Husker's Avatar
I have the same problem, These guys down south have it tough!
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 12-16-2011, 07:53 PM   #13
wyo tim
wyo tim's Avatar
The AC fresh air door is a great idea. Does anyone have any ideas of how to run it on a non AC truck.I wonder if it would be posible to control it via a controle cable, like a manual choke cable?
Old 12-16-2011, 08:24 PM   #14
1972RedNeck
That is true. But it is open unless the lever is moved to max A/C (recirculate), is it not?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-16-2011, 08:30 PM   #15
michael bustamante
michael bustamante's Avatar
SNOW? in your truck? you should post a video of that!
1967custom
michael bustamante is offline   Reply With Quote
Old 12-17-2011, 09:30 PM   #16
68 IRON
68 IRON's Avatar
I've had dry, broken leaves blow around but not snow....yet. I bet it looks like a snow globe, though.
68 IRON is offline   Reply With Quote
Old 12-17-2011, 11:28 PM   #17
ratrod67
ratrod67's Avatar
move
ratrod67 is offline   Reply With Quote
Old 12-18-2011, 12:03 PM   #18
sbc10guy
sbc10guy's Avatar
I dont know how to fix it but it even happened to me in my 92 gmc. It sucks, you try to turn on the heat and snow blows all over you.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 12-18-2011, 06:23 PM   #19
wyo tim
wyo tim's Avatar
LMAO, sounds like I need to post a video and have some holiday music in the back ground. Next time we get the dreaded snow I will try to at least get a pic for all you folks down south. Its no fun driving with an ice scraper in one hand and a starbucks in the other.
