Old 12-10-2011, 11:15 PM   #1
Baged72
Baged72's Avatar
Carrier Bearing is shot.. replace with 1 piece driveline?????
I have a 72 swb and it has 2 drive lines, i noticed the carrier bearing is shot and has lots of play, does this need to be replaced asap and why are there 2 drive lines vs 1?? Also my truck is on air ride would it be a good idea to just keep 2 for angel purposes?? Thanks
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 12-10-2011, 11:24 PM   #2
Bert W
Bert W's Avatar
Re: Carrier Bearing is shot.. replace with 1 piece driveline?????
Check out this thread and see if it answers some of your questions. Most, if not all of these pickups came from the factory with swing bearings. Never knew why though.
http://67-72chevytrucks.com/vboard/s...d.php?t=496863
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-11-2011, 02:39 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
with air bags I would keep the 2 piece driveshaft.
Take the assembly to a drive line shop and have it done professionally.
Old 12-11-2011, 03:43 AM   #4
Baged72
Baged72's Avatar
This an expensive job? Is the truck ok to drive still??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 12-11-2011, 06:33 AM   #5
WAAF
I just had my driveshaft redone.. I took it out.. the bearing was like 26 bucks and the 3 ujoints(usa made) installed was 83.oo (I got none greaseable as I've broken the greasable ones)
alittle over a c note if you have them do it all now.. and nows the time to have them all replaced
WAAF is offline   Reply With Quote
Old 12-11-2011, 10:54 AM   #6
Longhorn Man
it is very location specific as far as cost. I'd give my left lugnuts to be able to do it for 100 bucks. It's more like 200 here. 3 new joints, new carrier bearing and spin it and reballance if needed.
Old 12-11-2011, 12:20 PM   #7
50bomb
50bomb's Avatar
Well I only paid like $15-$17 for the standard setup . Heavy duty they are like over $100. Plus I did it myself. Very easy job, I do not see why spend so much money. Even I did it myself and I am dumb.
50bomb is offline   Reply With Quote
Old 12-11-2011, 01:16 PM   #8
Baged72
Baged72's Avatar
My truck does not vibrate or make noise but the bearing is shot can i still drive it for awhile?? I have a bunch of appointments for my truck and need to drive it to the locations for installations to get done, I don't have time to cancel them and reschedule...
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 12-12-2011, 12:34 AM   #9
americanmusc1e
americanmusc1e's Avatar
I kept the two-piece and went to a 3/4 ton driveshaft when I did my SM465 conversion..... my shaft has the larger carrier bearing and the big 1350 u-joints...... except for the rear which has a conversion joint until I buy a 1350 yoke for my 12-bolt.......
before that I was always killing u-joints and carrier bearings with the 383...... I also killed countless 700r4's and one 12-bolt
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 12-12-2011, 05:31 PM   #10
GRX
GRX's Avatar
I have had a few carrier bearings go out on me. If it doesn't knock around now, it will soon. If you can disassemble and reassemble a U-joint replacing the carrier bearing only takes few minutes.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
