Old 12-13-2011, 09:04 PM   #1
TehTaylor
Cluster swap
Hi you guys im new to the site and i have a 86 custom deluxe swb. it was a v6 auto to start with then was turned into a 5 speed, and now i own it and has put a 1969 327 v8 and a turbo 400 transmission. The truck came with the light up gauges, and I have a cluster with the manual gauges from a 82 swb and i was wondering if it was a straight swap or if i will have to do some wiring to make it work
TehTaylor is offline   Reply With Quote
Old 12-13-2011, 10:33 PM   #2
J Knight
J Knight's Avatar
Re: Cluster swap
From what Ive read you have to re-pin the cluster conecter plug and install sending units.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-14-2011, 12:29 AM   #3
TehTaylor
Re: Cluster swap
Do you know where i could get a diagram on which ones to switch?
Old 12-15-2011, 11:38 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Cluster swap
i just changed from idiot lights to factory gauge/tach
check my 78 jimmy out below.....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
