Old 12-15-2011, 07:21 PM   #1
duceducenine
duceducenine's Avatar
22 x 10 w/ 5" bs fit
will a 22 x 10 8 lug rim with 5" backspacing
285 45 22 tire -11.2 wide -31.9 tall
tuck in the front fenders of a 67 - 72 truck 2wd.
i have a 70 and a 72 i know the front
track is a little different because of the
disc brake but will it fit either truck????
need help soon trying to get these rims
this weekend.....from CL
thanks
duceducenine is offline   Reply With Quote
Old 12-15-2011, 07:37 PM   #2
gearheads78
gearheads78's Avatar
Re: 22 x 10 w/ 5" bs fit
A 10" rim is really 11" lip to tip so you ar looking at 6" of wheel outside the hub face. Then you have at least 1/4" of tire bulge. Take a wheel off and drop a plumb bob off the inside edge of your fender. Now take a tape measure and measure 6 1/4" out from the hub. The distance past the string is minimum how far out the fender the tire will be.
gearheads78 is offline   Reply With Quote
Old 12-15-2011, 10:18 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
thanks
No.
If it was an 8" wide wheel I would say yes.
Keith
Convert to disc brakes.
Old 12-15-2011, 10:22 PM   #4
Ackattack
Ackattack's Avatar
Being an 8 lug axle may throw things off compared to most with half ton axles. How wide is it?
Ackattack is offline   Reply With Quote
Old 12-15-2011, 11:19 PM   #5
duceducenine
not a good idea
Old 12-15-2011, 11:28 PM   #6
lolife99
lolife99's Avatar
not a good idea
It would be like bolting on a 15x8 ralley wheel (up front) with a 1" spacer behind it.
It's not going to happen.
Keith
Old 12-15-2011, 11:53 PM   #7
duceducenine
well right now i have 16.5 x 10
with a 4" bs on my 70 c20
6" from hub to wheel edge....
Old 12-16-2011, 12:06 AM   #8
El Campo
El Campo's Avatar
I have a set of Intro Pentia 20x10 with a drop in the front but have 275s and I would not do it again. This is on a 72. Do not rub but are too close for comfort and if you want to really "tuck" them it isnt going to work right. I also have 5 inch BS.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-16-2011, 10:45 AM   #9
duceducenine
nobody with pics?
Old 12-17-2011, 11:50 AM   #10
El Campo
El Campo's Avatar
I took mine off and am sending them to get rehooped down to 8.5 because they just didnt really work period. Otherwise I would take a picture and you could see what I mean. The outside of the rim and tire were where the lip of the fender should be. I love the idea of having all that wheel in the front but with a 5 inch backspacing mine did not work well enough to keep that way
Hook em Horns!!!
Old 12-17-2011, 03:08 PM   #11
duceducenine
thanks for the info i guess i'll leave them
alone dont need more parts i cant use.....
