Old 12-15-2011, 03:14 PM   #1
blackmopar
what brake m/c for disc swap?
Whats up guys
1964 C10 - currently have the stock drum/drum with power booster single res m/c
Im grabbing the drop spindle/disc kit from speedway:
http://www.speedwaymotors.com/1963-7...Kit,46257.html
and need to get a dual res m/c for disc/drum.
What year/model should I go for here - Id like to keep my current booster etc to keep cost down
can i use a 68-82 vette or something better/cheaper?
thanks!
blackmopar is offline   Reply With Quote
Old 12-15-2011, 03:20 PM   #2
dallas71
dallas71's Avatar
Re: what brake m/c for disc swap?
I used a m/c from 68-72 chevy truck and the proportional valve from the same and bolted right up (without booster) just had to adjust the brake pedal for proper length
dallas71 is offline   Reply With Quote
Old 12-15-2011, 05:38 PM   #3
badriand
badriand's Avatar
Guess i am cheap. i grabbed the upper/lower control arms spindles booster and prop valve and all off a 87 suburban. Bolted right up also except booster had to drill a couple holes.
badriand is offline   Reply With Quote
Old 12-15-2011, 06:26 PM   #4
blackmopar
Badrian - I normally am too, and actually i got the whoel front end from an 85 c10 that i was going to use - along with some drop spindles, but after adding the money up to overhaul the front end and buy spindles, etc I was still at a few hundred bucks, plus i got some funny money for speedway so this 'kit' sounds like the ticket to me - Ive got the m/c from the 85 that would probably work but its that smallish unti with the plastic reservoirs - kinda not the look i want
did all 68 up corvettes have disc/drum combos? just not sure about whether the bore size will be right
Old 12-15-2011, 07:45 PM   #5
64shortbox
64shortbox's Avatar
blackmopar,
did you see this disc/drum master available from Speedway? It isw available in both 1' & 1-1/8" bore sizes and has brake line ports on both sides of the master. It's $59.00 new. Here's the link:
http://www.speedwaymotors.com/Master...akes,4316.html
Hope this is of some use to you.
64shortbox is offline   Reply With Quote
Old 12-15-2011, 07:48 PM   #6
64shortbox
64shortbox's Avatar
oops,
here's one more disc/drum with dual ports and it's $10.00 less than the other ones. Here's that link:
http://www.speedwaymotors.com/GM-Cor...ore,51673.html
Old 12-16-2011, 12:39 AM   #7
Captainfab
60-66 Nut
All you need is a master for a '71 and up truck, as well as the proportioning valve for the same.
Old 12-16-2011, 06:03 PM   #8
blackmopar
thanks guys! hope santas good to all of ya!
Old 12-17-2011, 01:42 AM   #9
64shortbox
64shortbox's Avatar
I would go with what Captainfab suggested. That way if you need another new master cylinder at 3 PM on a Sunday you can go to your local parts house and get one. You wouldn't have to wait a few days to get another one from Speedway etc.
Old 12-19-2011, 06:31 PM   #10
blackmopar
very valid point amigo!
