Old 12-12-2011, 11:01 PM   #1
mooseknuckles
mooseknuckles's Avatar
6.0L - th700r4
so I'm thinkin bout gettin a Lq9 6.0L from the wreckers, can I bolt my old 700r4 tranny up to the Ls motor?..and will it work?...or do I need to get the 4L60/4L80e? I'm new to the Ls swap scene, so any help would be really appreciated.
mooseknuckles is offline   Reply With Quote
Old 12-12-2011, 11:34 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 6.0L - th700r4
Yes you can, but you will need to run a cable type throttle body for the TV cable. If you buy a motor with DBW, you'll need to convert it to cable.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-12-2011, 11:42 PM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 6.0L - th700r4
You can, but as mentioned you will need to do something about the TV cable, which will pretty much require swapping the DBW throttle body to a cable throttle body. Also you will need a 0.400" flexplate spacer to make up for the shorter crankshaft in the LS engines.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 12-13-2011, 07:44 PM   #4
mooseknuckles
Re: 6.0L - th700r4
ok so if I carb my 6.0L the 700r4 will be no prob, or else I need the drive by cable 6.0L? which is basically the gas pedal hook-up, electronic or cable right?...and Im guessing I'll need the flexplate and spacer kit Ive been seeing from TCI?....what model years are the cable?
Old 12-13-2011, 08:24 PM   #5
okieraptor
okieraptor's Avatar
Re: 6.0L - th700r4
2000-04 i think. Im looking to the same as you.
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 12-13-2011, 09:44 PM   #6
LEEVON
Moderator
LEEVON's Avatar
Re: 6.0L - th700r4
Yes you can. You need the TV cable set-up for drive by cable throttle bodies from bowtie overdrives. And you also need a crankshaft spacer.
Bam: http://www.bowtieoverdrives.com/cata...php?ITEMID=225
Boom: http://paceperformance.com/i-6509791...k-adapter.html
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-13-2011, 11:00 PM   #7
usmcchevy
usmcchevy's Avatar
Re: 6.0L - th700r4
most 03+ trucks got DBW, you can convert any LS a cable type TB by replacing the TB changing the wiring and a different computer tune.
If your engine had a 4l80e behind it(most likely), it will already have the spacer behind the flexplate.
http://67-72chevytrucks.com/vboard/s...d.php?t=455803
Build thread
LSx Swap FAQ index
Old 12-14-2011, 09:34 AM   #8
GCncsuHD
GCncsuHD's Avatar
Re: 6.0L - th700r4
He said LQ9, which will have the 4l65E, not the 4l80E, so no spacer.
ΜΟΛΩΝ ΛΑΒΕ
Old 12-14-2011, 10:55 AM   #9
usmcchevy
usmcchevy's Avatar
Re: 6.0L - th700r4
Missed that, So yes you will need the spacer, bolts and flexplate.
Build thread
LSx Swap FAQ index
Old 12-14-2011, 08:35 PM   #10
mooseknuckles
Re: 6.0L - th700r4
ok thanks....so Im best to get the motor and tranny as a complete package to save time and money?
Old 12-14-2011, 11:55 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0L - th700r4
sometimes yes, but because of the popularity of these swaps, complete packages can s actually cost more. If you know what parts your looking for, sometimes peice mealing them is cheaper.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-15-2011, 01:52 PM   #12
CamaroChris
Re: 6.0L - th700r4
You CAN use the DBW with a 700-R4 You just have to get crafty
Bottom of this page
Link
Or
Link
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 12-15-2011, 03:28 PM   #13
okieraptor
okieraptor's Avatar
Re: 6.0L - th700r4
http://www.tvmadeez.com/ls1_cam/
Old 12-17-2011, 01:36 PM   #14
mooseknuckles
Re: 6.0L - th700r4
cool....thanks.
Old 12-17-2011, 03:51 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0L - th700r4
oh, and the lq9 will smoke a stock 700r4 unless you are super easy on it. Guys get built ones that hold up, but at that point the money is better spent on a better trans to start.
Old 12-17-2011, 03:54 PM   #16
mooseknuckles
Re: 6.0L - th700r4
good to know...thanks man.
Old 12-17-2011, 09:14 PM   #17
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 6.0L - th700r4
LQ9 had like 380tq?...so call it 400 ft lbs.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-18-2011, 11:31 AM   #18
mooseknuckles
Re: 6.0L - th700r4
....so I'll guess I'll go with my first plan and find a complete 6.0L/460le combo, and save myself some heartache down the road.....I found a bare bones 2000 5.3L dbc, but he wants too much money $1200....
Old 12-18-2011, 01:20 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0L - th700r4
if your buying them together, you can find the 6L with a 4l80e, but it will usually be a lq4. You can also find them with the 4l65e if your looking at a new enough motor.
Old 12-18-2011, 10:16 PM   #20
jpstaub
Re: 6.0L - th700r4
Hello,
I know it's not exactly what you're looking for, but I completed an LQ4 swap backed by a 700R4 transmission on my '72 C10 this July. To cut down on my troubles, the donor vehicle for my LQ4 was an '06 3500 series Chevy Express van (read Pirate 4x4's LS Primer for more on donor engine specifics). By going this route the engine was: 1. relatively low miles at 60k, 2. set up for a cable throttle which substantially eliminated the TV cable problem, 3. came with a flex plate I easily modified to work with the 700R4 converter.
The dipstick tube and oil filler had to be modified but those were easy fixes. I also put a different power steering pump reservoir on since the van I got my engine from used hydra boost and I wanted an integrated reservoir--not too big a deal.
For the TV setup I used a kit from Bowtie Overdrives.
I don't know what shape your 700R4 is in so it's hard to say what might happen if you start romping on your truck after the swap (hard not to do). The Level 2 700R4 Bowtie Overdrives transmission I've got installed in my truck is doing quite well thus far.
The only other big item looming is the wiring harness modification. If you want a bunch of van LQ4 specific info to help you mod a harness to match the one I came up with which is working with no faults let me know and I'll send it along. There's no real cosmic differences between the van and truck harnesses that I noticed. Just a few things that are different and took a little additional research to pin down.
Best wishes,
Jake
jpstaub is offline   Reply With Quote
Old 12-18-2011, 10:36 PM   #21
mooseknuckles
Re: 6.0L - th700r4
thanks for the info.....my 700r4 is running perfectly now...Ill keep looking for a complete set up cause I really want it fuel injection, but it just depends on whats out there.....although there aint nothin wrong with a carb'd 6.0l
Old 12-18-2011, 11:38 PM   #22
jpstaub
Re: 6.0L - th700r4
I think I may have lost you. My swap involved a factory fuel injected 6.0L (LQ4) backed by a 700R4.
Jake
Old 12-19-2011, 07:29 AM   #23
mooseknuckles
Re: 6.0L - th700r4
lol..I got that but, if I can get the whole setup, motor/tranny, everything... its stayin fuel injected, but if I can only find just the motor it will be goin carbuerated for a while. either way I guess it will work...thanks.
