Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-20-2011, 08:16 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Transbrake vs high stall
I remember hearing about a TB in or around '85. My brother-in-law had a 10 sec flat '68 shuvelle that was pretty heavy. I remember the few cars that had them back then were very light and he always said it's a great way to break a bunch of sheet. His analogy was to put your car in park, rev it to 5K then put it in drive. I realize that it holds the car in first and reverse at the same time. He used to say it's an incredible shock to the drivetrain.
I did a thread a short while back about how fun my little ole 3,000 stall converter is in my Camaro since I have never had anything like that. I'm already starting to hunt for a roller valve train and plan on doing what we all do......hunt for more power. I hear some guys talking about leaving on the brake and then the same guys foot braking it. What are the pros and cons to a TB vs a super high stall? Is it important to match a TB with the right stall at the same time? Marv also wrote that simply installing one without the trans being gone through is just a waste. Will she flat destroy a stock TH400?
Just looking for some thoughts or even a killer link on the subject. Wiki can be good but is weak on this subject.
prostreetC-10 is offline   Reply With Quote
Old 11-20-2011, 08:27 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Transbrake vs high stall
http://www.hughesperformance.com/
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-20-2011, 09:45 PM   #3
Super73
Super73's Avatar
In my opinion a transbrake is used for two reasons. In no specific order, the first is to get the most out of your ET, the second to help consistancy. Any sized stall can work with a brake, but you start to loose consistancy the bigger it is.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-20-2011, 10:14 PM   #4
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
http://www.extremeautomatics.com/pro...lvebodies.html
This guy designs and builds his own TBs. So he'd be the man to talk to for sure.
ProStreet68SB is offline   Reply With Quote
Old 11-20-2011, 11:54 PM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
Any class run on a pro tree a transbrake has an advantage over a footbrake car imo. Also with a transbrake the suspention is at rest on a footbrake the suspension is loaded . Converter needs to be per set up . A looser converter helps a footbrake bracket car .
Might look into Jakeshoe performance in Dallas . He has a manual auto 400 VB in both electric solinoid and hydraulic .
http://http://www.jakesperformance.com/Home_Page.html
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-21-2011, 01:12 AM   #6
prostreetC-10
My Carbon Footprint
Thanks! Actually, Jake seems to be a regular over on the Nasty Z28 forum. He gave me a couple of tips when I put the transgo kit in my TH400. Seems like a true auto guru.
Old 11-21-2011, 01:19 AM   #7
prostreetC-10
My Carbon Footprint
I'm really starting to think that I'm not ready for a transbrake. I need to go out and have some fun with my currect setup first. Thanks guys!
Old 11-21-2011, 04:10 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
This is the valve body im going to try : I have a trans specilties now :
TH400 Automatic Shift Electrically Operated Transbrake
Others have said they could do it, we have actually done it!
Operates as a stock type valve body with automatic shifts and modulated line pressure. Engage manual low, hit the button and you have a transbrake.
Introductory price of $200.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-21-2011, 03:01 PM   #9
fastwillie 696969
~Rest In Peace~
i love the transbrake ,i would never be able to footbrake as fast as releasing the button for TB,it seem it hooks up better too ,maybe some of these guys who use it more can tell ya
Old 11-21-2011, 06:04 PM   #10
regan wilson
regan wilson's Avatar
One of the most important things is to have the line lock wired in with the button. You will mash the brakes hard when you set it so it wont rock back. The reason for this is you do not want to not unload the ring and pinion or the suspension. And not to argue but when you pull to the line under power and load against the brakes and the trans brake, the suspension is loaded not rested .It may feel like doing a neutral drop when it leaves but not the same. Still though you have to have good parts to stand the abuse.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 11-21-2011, 06:25 PM   #11
prostreetC-10
My Carbon Footprint
This almost reads like a double negative. I just want to be sure of your info. Are you saying you want the suspension loaded or at rest? Seems like loaded would be easier on parts.
If some of you read my other NEW thread, no transbrake for me now since I wiped a cam lobe last night (or at least discovered it). I am now searching for a roller cam.
Old 11-21-2011, 09:09 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Something else to think about , here there are 2 classes . Footbrake and electronic/pro . You cant run a transbrake in footrake class .
Sorry to hear about the cam issue .
On the suspension loaded or unloaded . I have never used a linelock with a transbrake so i cant speak there . I also dont stage with the motor rev'd up i just ease up there , courtesy stage ,, when the second buld comes on i hold the button and mat id up against the 2 step . My suspension isnt loaded . It is at rest . Im on leaf springs so i sit different them the big trucks . Not wanting to argue here either , but im game for learning something for sure . I was always told if the trans creeps it has problems with band adjustment/clutches .
Hope im not hijackin'
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-21-2011, 09:31 PM   #13
vin63
It's Better With Nitro
vin63's Avatar
I run a pro style transbrake in my Super Gas/Street car for 20+ years, and the advantages are consistency and reaction time. The stall rate of the converter you choose has more to do with the power band of your engine combination. Yes, it is important to have a race-built transmission and driveline that will withstand your plans for the car if your are going to do high RPM launches with either footbrake or transbrake - also keep in mind if you have a TH400, that the shift pattern will be reverse with a transbrake.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-22-2011, 07:01 PM   #14
regan wilson
Ok ! Ive had mine on the scales 100 times . Chassis scales that is . With a vehicle in neutral the suspension is rested . If you pull to the line in gear at an idle it isnt.
Old 11-22-2011, 10:30 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
I see . I have only been on corner scales 3 times and never with this truck . I can see exactly what you are talking about . Learn something everyday .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-17-2011, 01:52 PM   #16
scatesracing
Machinist
scatesracing's Avatar
My two cents..... Its a pain in the ass on the street. reverse pattern and manual valve body.hold tranny brake button for reverse or flip the swith and flip it back, all while wrestling the full spool on 14" tires with a 5300 stall... I wouldnt change a thing. One other thing. It keeps my wife from wanting to drive it.
scatesracing is offline   Reply With Quote
Old 12-17-2011, 07:02 PM   #17
ont_guy_38
ont_guy_38's Avatar
LMAO yes even though something like that is a pain in the ass to drive you still smile when driving it . Mine is no where near that bad and ya my wife won;t drive it either
ont_guy_38 is offline   Reply With Quote
