#251 |
Windy Corner of a Dirty Street
Re: NV4500 swap is underway
Yep, Chevrolet has only used the same bell housing pattern on their engines for the last 60 some years.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#252 |
would i use a bell of a 90's chevy 350 for the bolt pattern on the nv4500
#253 |
TAg for use soon.
#254 | |
Future TOTM Winner
![]() You would have to use a bell housing off of a 93+ nv4500 that was behind a 350 or 454 (i'm not sure about the 6.5 diesels but probably the same also). There were a lot of sm456 trannies in the 3/4 - 1 tons from 88-92 that won't bolt up to the nv4500. You might already know that, just making sure.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#255 | |
#256 |
Future TOTM Winner
Your right, I was just giving you a hard time mainly. That's why I used the word "overlap". However, I have had people tell me that my bell housing pictured above IS NOT for a chevy after they see that bolt hole at the top. Guys that are just unfamiliar with the LS engines.
#257 | |
#258 |
I just acquired a 1983 k10 with a 350 and a 3 speed with a.granny gear it is strong but. It keeps popping out of granny gear. I was playing with it in the yard and noticed it won't hardly go in gear or stay in gear. Let me ask you. How hard would it.be to switch to a 350 turbo or.700 r4 this.truck is for my son. So a automatic might be better for him
I hope this is not what they call hijacking your thread but. I thought.you might give me a clear answer thanks Posted via Mobile Device |
#259 | |
#260 |
Awesome job! I am wanting to do this to my 71 K10. Currently running sm465, but I ran across a thread about having to have a vehicle speed sensor and was wondering if you installed something to that effect to make it run right or if you were able to run the speedo cable to the transfer case without any issues.
#261 |
Future TOTM Winner
Larry, I went back and reread this and didn't see an answer to the question I'm about to ask...did you consider a ZF6 manual tranny at any time? If so, was price a deciding factor or do you simply like nv4500s that much more?
#262 |
Muckmorris,
I am not running any kind of speed sensor. Just the stock speedo cable from the NP205 tcase to the speedo head. Critter, Nah, I never considered a ZF S6-650. I have one of those behind an 8.1L in my 2500HD and not real fond of it. It is one awkward shifting transmission. Have you ever driven one? The NV4500 is so much nicer shifting. Aside from that, I don’t think it would fit without a body lift or significant firewall and trans tunnel work. The ZF is HUGE but is probably a much stronger trans than a NV4500. I haven't heard of any ZF's with OD gear set issues or anything else that the NV4500 are famious for ![]() ![]() ![]()
#263 | |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 12-19-2011 at 02:50 PM. |
#264 |
thanks for the feedback Dirty larry
#265 |
Hey Larry,
What bellhousing did you end up using? I scanned the thread but didn't see where you mentioned this. I just picked up an NV4500 this afternoon for my C/10 but it didn't come with a bell, I still think it was a deal. |
#266 |
Quick question for you larry since you have experience with the gm zf 650, have you ever driven the dodge 6spd behind the cummins and if so which do you think is a better shifting tranny or has better driveablility? I had an early 24v cummins 2wd 6spd i got dirt cheap as a tow truck then drove a 12v 5spd and absolutely hated it the wide ratio shift is so annoying i felt like my arm was fully extended in 5th. I was also interested in how different the dodge and gm 5spd shift patterns are unless there the same
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold 2003 1500 Silverado - Selling 2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LB SRW |
#267 | ||
![]() Quote:
Regarding the 5 speeds, sounds like the 12v 5speed you drove was an old Getrag or an early NV4500 with the first generation trans cover and shift tower. Those did have a large throw to poke them up into 5th gear. The later (after 1994 or 1995) got a tighter shift pattern. I don’t think what you described is a GM vs. Dodge trans versions, just more of the early vs. late transmission versions. There are definitely more people round here that know NV4500’s better than I do to know for sure. I will say this though, of all the truck type manual transmissions I’ve driven the NV4500 is by far my favorite. It is not a sports car transmission, but compared to a SM465, ZF S6-650, NV5600 the NV4500 might as well be a sports car transmission. I would love to drive a G56 in a later model Dodge to see what those are all about.
#268 |
Ah, I noticed the other day that it has almost been 10,000 miles since the NV4500 swap was complete. These miles aren’t cruising around town miles but traveling on off-road adventure trips around Arizona, Utah and fishing trips to the local mountains. With almost 10K on it, it still works just as nice as it did right after the swap in March of 2011. I still love it!
#269 |
I can't remember which 12v it was but i thought it was the last i think 2 years of them and i towed my mud truck with it which pulled it fine but i just could never get use to that shift pattern and always wondered about the ZF because i thought a mud truck with a 6spd would be something fun but i want a fast shifting one like a t56 or a clutchless style shift like a lenco or jerico but i am not sure how well car ratio'd trannys would transfer into a 4wd truck
#270 |
Ouch, it looks nice but 366 is a little more than I paid for the trans!
#271 | |
1992-1995ish bell with the external slave cylinder. The downside is the slave falls on the passenger’s side which can cause interference issues depending on your exhaust configuration (with yours being a 2wd you wouldn’t need to worry about the front driveshaft interference). You would also need a 1992-1995 design clutch master cylinder along with the hose. 1996-2006 bell housing with an internal slave/release bearing assembly. These don’t work well in older trucks as the trans and bellhousing assembly must be stuffed into the truck in one piece. This is an issue being there isn’t room to stuff NV4500 with the bell attached into the truck in one piece unless the engine is out where the trans can be installed through the front then install the engine. For these reasons is why I went the AA bellhousing. With yours being a C10, a NV3500 would probably be a better trans to use but the bell is part of the transmission assembly where it too can be a hassle to stuff up into an old truck due to clearance. Once it is in there, it is fine….getting it in there is the hard part.
#272 | |
#273 |
Larry, with that AA bellhousing, do you have the option of going with mechanical clutch linkage? What are the advantages of a hydraulic clutch anyway?
Also, I'm surprised to hear about your issues with the ZF6. My work truck is an 04 Duramax 2500 HD with a ZF6 and I love it. If I read your posts correctly, you start out in 1st? I never do, I start out in 2nd as 1st is 5.79 or so. So shifting 2-6 is just like driving a regular 5 speed. It is actually the same shift pattern as my 02 Jetta, with the exception of the Jetta missing creeper gear. I wasn't ever thrown too far off by the reverse location of the ZF6 either as I was used to reverse being to the left on my old sm420.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
#274 | |
I don’t have issues with the ZF in the Silverado, I just don’t like it. The shift pattern is clumsy and awkward plus the clutch engagement isn’t as smooth as the old trucks. The clutch engagement isn’t the ZF’s fault but more of GM’s pizz poor clutch design on the GMT800 trucks. The clutch works like an on and off switch, with no smooth way to launch the ZF truck. I bought the truck brand new and it has been like this since day 1. The dealer even put a new clutch and slave while it was in warranty to no avail. I don’t start off in granny gear either. I start off in what you are calling second. The only time I use granny gear (1st on the knob) is when towing very heavy loads or the need to go super slow. One thing I really hate about the ZF is how easy it is to stick in reverse when you are aiming for 1st (second if you go by the letters on the knob) as you roll up to a stop sign. I’ve surprised a few people taking off from a stop in reverse instead of 1st. ![]() Between the crappy clutch engagement and the awkward shift pattern, I don't care for the ZF in the Silvy. I don't drive it much anyway. In 11 years of ownership it only has 55K miles. I prefer a NV4500 or NV5600 any day over the ZF S6-650
#275 |
Hmm according to the wikipedia article about the zf6, there were some revisions made for the GM version in 2001. Maybe yours was a transition model? On mine there almost feels like a lockout that keeps me from putting it into reverse as opposed to 2nd.
I know what you are saying about the clutch though, I would describe mine as "grabby." That Duramax that I don't need to give it any foot feed when starting from a stop, but if I do, its not smooth at all.
