sound proofing (great stuff)
So exploring my cab i noticed alot of chambers in the cab that could get filled up with great stuff (minimal expansion of course) has anyone tried this?
Posted via Mobile Device |
Re: sound proofing (great stuff)
great stuff absorbs water!
Senior Enthusiast
Welcome to the forum!
You might want to review this thread before making any decisions on the use of foam in your truck: http://67-72chevytrucks.com/vboard/s...highlight=foam |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I pulled foam insulation out of my cab corners that someone previous put in.
Junk - it holds moisture against the metal. Posted via Mobile Device
Lizzard Skin is a waterproof, sprayable sound deadener. You could probably find an undercoating gun with attachments to apply it in hard to reach areas.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Ive heard great stuff about the Lizzard Skin
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Jun 2011
i knew the guy that won the world SPL (sound pressure level) contest for 1991 and he used pure silicone with a calking gun. may be more expensive but the panels were dead.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
![]() Join Date: Jul 2010
You need closed cell foam..not open cell
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
..and probably the most important thing would be good adhesion. Still don't want moisture setting between the foam and the panel.
#10 | |
Here's a cab I sprayed with Lizzard Skin's Sound Control and Heat Control coatings, two coats each. It's a little over the thickness of two credit cards and has a nice texture. It's also sandable/paintable, and you can spray high build primer over it and block it flat. ![]() ![]() ![]() ![]() It dries black. ![]() ![]()
Whats the thought on application of the Liz skin. Must spray? Or roll/brush? Other options that are cost effective?
If I were to do it again, I'd only buy their sound control spray. You can make your own heat insulation by buying ceramic beads and mixing them in with your own paint/primer. Here's a link with more info about making your own very cheaply.
http://www.hotrodders.com/forum/alte...in-103610.html Posted via Mobile Device
Thanks everyone for posting! markeb01 posted a link to a previous discussion on this very subject. It seemed 1/2 and 1/2 on expanding foam. It looks like spraying foam to bare metal makes it rust faster which makes sense because of condensation. So would painting the metal before adding the foam solve that problem? How could you paint both of the inside panels of the ceiling/roof? Some people mentioned closed cell instead of open cell. How does closed cell foam react to bare metal? I have heard a lot about lizard skin but it can only reduce sound/vibration. I'm thinking that closing the gaps between 2 vibrating panels would make a way bigger impact. any thoughts?
i used truck bed liner and the roofing rubber on the entire metal floor. (nobody will see it don't tell anyone)
#15 |
I por 15'd the complete floor and back wall, then added butyl rubber with alum backing and adhesive from home depot. (roof flashing material) about 1.25 per sq foot, then added A/C duct insulation alum shin, closed foam with adhesive on top of the sound deadner. cost about 1.25 per sq ft. my cab is tight, quiet, and warm.........did not cost much.....you could use your lizard skin and then add the above items and really quieten it down and insulate it. Only draw back ....had to use a ray buck full rubber floor mat then a stock one on top of that so the shiny alum would not show since we could not paint it. If you are going to carpet it no problem.. Kieth
#16 |
OK, y'all are freaking me out....I welded in new rocker panels a couple of months ago, and filled with Great Stuff, to (I thought) keep them from filling up with water.....
#17 |
I know it seems like a great idea, but it really isn't. Not much you can do about it unless you want to cut them out...
#18 |
I work for Dow chemical.We make Great Stuff. It is not for use in body repair. The proper Foam is used in newer vehicles that have been properly prepared using modern corrosion protection methods.
#19 |
This is unrelated to Great Stuff, but here's a project I did on my Mercedes a couple years back. I learned a ton about soundproofing while doing it.
http://www.peachparts.com/shopforum/...-84-300td.html There's a ton of pages and notes in there that should be helpful for anyone looking for information on soundproofing.
66 Chevy C10 Stepside LWB My Build Thread 75 Harley FLH 84 Mercedes 300TD Diesel Wagon |
#20 | |
![]() Join Date: Mar 2011
#21 |
I'm definitly going to try the home made ceramic bead insulation under the floor and inside of the firewall on my '66. It seems it's more for heat insulation than sound, so I'll use it over a couple coats of Lizzard Skin's sound control coating.
