Old 12-21-2011, 12:45 PM   #1076
big_al_71
big_al_71's Avatar
Re: Al's 71C10 Rebuild
Well I got up early today and went over to a local place called parker store. I bought some air line and fittings. Went to the house and fixed my left front air line and the truck is ready to go. I have to get my exhaust redone which may have to wait till january because of the holidays. we need to install the E3 leveling sensors as the wires were ran already is just a matter of mounting the sensors. I left to work earlier today but took some parting shots before I left....
Man I am so happy that this truck is off the jackstands.....
I can not Thank Raul enough for everything he did to make my truck come out the way that I always wanted........
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-21-2011, 12:52 PM   #1077
big_al_71
big_al_71's Avatar
Al,... I ran both my front air lines down the passenger side frame rail.
I connected to the passenger side bag routing the line thru the crossmember.
The drivers bag I also routed thru the crossmember under the engine.
Any time I run air line thru sheetmetal or the frame,... I run it thru a rubber grommet.
I also wrap the air line is some sleeving made by Painless Performance Products.
It helps protect the tubing from chafing.
http://www.jegs.com/webapp/wcs/store...Id=10002&Nty=0
How did you cut the air line tubing?
Keith
We were adjusting the proportioning valve and while driving around my neighborhood we went thru a lazy left turn the line just went boom we thought that the line came off the bag as the way it sounded. We looked and could not figure out how or why it got a hole on it. we are thinking that maybe we left too much slag on the line and as we were turning it got pinched so this time we made it a bit tighter. I am waiting for Raul to come back into town so that he could go over all the lines as it "SUCKED" being stuck not able to move I had to call my wife to come get me then I had to come back with a floor jack and put the hard aluminum bump so I was able to drive it back home but if that happened on the road it would not be good.
thanks for your explanation. what I am thinking is driving it to my shop and putting it on my aligment rach so that I can see what the suspension does and determine if there may be an issue when aired out or while driving.
Old 12-21-2011, 01:38 PM   #1078
thor
thor's Avatar
Wheels look great! I love how the fender lip comes just even with the top of the wheel. Perfect stance!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 12-21-2011, 01:43 PM   #1079
superflysteiny
superflysteiny's Avatar
Al you can see the line running up behind the shock tower in the first picture. I put a piece of rubber hose over it so it would not wear on the bracket.
In the last pics you can see I drilled a hole in the back of the airbag bracket put a piece of fuel line hose through the bracket and ran the airline through the hole. In to the 90 degree adapter in the bag. So the line runs from the back of the truck on the inside of the frame. Goes through the old upper shock mount hole. Behind the porter built shock bracket and throught the center of the upper bag mount to the bag. At every point that I went around a bend or through the frame I put fuel line around the airline so that it would not wear a hole in the airline. Hope this helps.
superflysteiny is offline   Reply With Quote
Old 12-21-2011, 01:44 PM   #1080
superflysteiny
Sorry made one mistake ran the line through old emergency cable hole not old shock mount hole. Sorry
Old 12-21-2011, 02:05 PM   #1081
CC69Rat
CC69Rat's Avatar
So, what's next ?? You need 'Tweety' now. A drop membered / body dropped 68, in Lambo yellow maybe ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-21-2011, 03:49 PM   #1082
big_al_71
big_al_71's Avatar
Thank you...
Eric thanks for the pictures..I will use them as reference to compare to how we ran mine....
Not a bad idea...Next project will be a "porterbuilt" body drop for sure..
Old 12-21-2011, 05:21 PM   #1083
class01
class01's Avatar
Bada$$!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
class01 is offline   Reply With Quote
Old 12-21-2011, 06:26 PM   #1084
dmwphoto
dmwphoto's Avatar
looks fantastic and I bet it is a blast to drive.
one small nit... that back bumper looks bent?
dmwphoto is offline   Reply With Quote
Old 12-21-2011, 06:37 PM   #1085
big_al_71
big_al_71's Avatar
It is the picture the way it looks it is the reflection from the chrome
Thank you!!
Old 12-21-2011, 06:39 PM   #1086
dmwphoto
dmwphoto's Avatar
glad to hear that. Sweet dang truck build there
Old 12-21-2011, 06:45 PM   #1087
crappiewrangler
Man....That is one sweet ride. It never ceases to amaze me what a set of wheels will do for the looks of a truck..Very good selection...
crappiewrangler is offline   Reply With Quote
Old 12-21-2011, 07:05 PM   #1088
raull
raull's Avatar
zup bud , i got all your pix , im glad your happy , sorry i missed all the exitement on the arrival of wheels !!! im back in town so ill stop by tonite !!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 12-21-2011, 07:12 PM   #1089
lolife99
67-72 parts collector,…
lolife99's Avatar
Congrats again for doing a quality "make over".
I bet most would be surprised by the amount of money you layed down to do these mods.
The RideTech suspension parts, RideTech air management with the leveling system, RideTech tubular a-arms and their PRICEY MuscleBar sway bar.
Then add 20" Billet Specialties billet wheels and steering wheel.
Almost forgot the 4-wheel disc brake mods.
You did your home work and spent your money ($$$) wisely.
The results are stunning!
Keith
Convert to disc brakes.
Old 12-21-2011, 10:07 PM   #1090
big_al_71
big_al_71's Avatar
100% for sure wheels and stance make up a truck/car or it can kill it..
Zup brother man I am glad you came by and help me figure out why the line went last night. I am sure that now we are all set and ready to go.
Keith thanks for all your help as usual..I definetly spent a great chunk on $$$ this time around let alone in the whole truck since we started in 2008 and remember that 90% of all the labor was done in house by friends and I so I saved alot of $$ on labor..
I am still not done as I have many misc items that i want to replace just because of wear and not up to the standards of what i want to accomplish.
I AM EXTREMELY GRATEFUL TO MY BUDDY HARRY, JOHNNY AND RAUL WITHOUT THESE GUYS THIS TRUCK WOULD NOT HAD BEEN BUILT.
Old 12-21-2011, 10:15 PM   #1091
HarrySmith
Looks awesome man! Thats what we should have done from the start!
Glad I was a part of it, wish I was there for this!
HarrySmith is offline   Reply With Quote
Old 12-21-2011, 10:15 PM   #1092
msgross
msgross's Avatar
I likey...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-21-2011, 10:16 PM   #1093
bobshotrodblazer
BigBlockBobby
Truck rocks Al, Good job.
Bob
bobshotrodblazer is offline   Reply With Quote
Old 12-21-2011, 10:25 PM   #1094
hayhauler71
hayhauler71's Avatar
Looks great Al a job well done
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 12-21-2011, 10:31 PM   #1095
big_al_71
big_al_71's Avatar
This has gone thru my head a thousand times I should had listened to you out of the gate. As you know that I am super grateful to you for EVERYTHING you did for me.
Thanks bro!!!!
Originally Posted by msgross View Post
I likey...
Thanks Big Mike!!!
thanks Bob!!!!!
thanks Fuzzy....
Old 12-21-2011, 11:48 PM   #1096
N2TRUX
Happy to be here
N2TRUX's Avatar
Dude your truck looked "good" before, and now it freakin rocks. Your investment paid big dividends.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-22-2011, 12:24 AM   #1097
big_al_71
big_al_71's Avatar
Thank you Ken!!!!!!!!
Old 12-22-2011, 12:24 AM   #1098
PTS
Junior Member
PTS's Avatar
Hey Al,
Did you find the shank lugs? Also I am looking for a swb fleetside bed only for a 67-72. Let me know on the lugs and the bed when you get a chance. Also did you post pictures of your truck on Pro Touring?
Regards,
Perry
PTS
Great Deals for 67-72 members on Billet Specialties, Intro Wheels, and Ridetech!
Toll Free 1-855-353-7885
PTS is offline   Reply With Quote
Old 12-22-2011, 12:30 AM   #1099
big_al_71
big_al_71's Avatar
Originally Posted by PTS View Post
Hey Al,
Regards,
Perry
PTS
Hey Perry
Yes I found the lugs at wheel world down the road from my shop and I already installed them.
also take a look at this link
http://www.pro-touring.com/showthrea...529#post865529
Thanks for everything I will keep an eye out for a swb bed for you....
Old 12-22-2011, 02:59 AM   #1100
nibs
JRods Garage
nibs's Avatar
Hey Al, Im curious about the wheel clearances on your fronts. Im talking to Perry about some Intros and Id love to hear some feedback from how much room you have with yours...
An Im amazed at the drastic change your truck has made! I know how you feel about how much was spent and the changes it gives you. I just bought a front dropmember and some rear goodies from Nate. All that money that nobody will be able to see! LOL
Keep up the good work
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
