Old 12-22-2011, 01:45 AM   #1
69C-owner
69 Custom/10 1/2 Ton rearends???
What was available off the assembly line, I know there was nothing but drums on the rear so there is no question of brakes but gears, 10 bolt, 12 bolt, dana? Posi?? Unload the knowledge guys
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 12-22-2011, 02:02 AM   #2
69Beauty
69Beauty's Avatar
Re: 69 Custom/10 1/2 Ton rearends???
Dont know about anyone elses but my 69 custom/10 1/2 ton has a 12 bolt with 3.73 gears with a factory posi in it.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 12-22-2011, 07:35 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
My 69 C/10 short step has it's original 12 bolt 3.73 non posi still in it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-22-2011, 08:15 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
just about every C/10 ended up with a 12 bolt in it. A handfull ended up with a Dana, more GMCs than Chevy trucks did though... but still a rare find (and I hate useing that word)
As far as gearing, they came with 4.10, 3.73, and 3.07. They were all standard with certian engine/tanny options.
General rule of thumb without breaking out my books...
3 speed on the column got 3.73.
4 speeds generally got 3.07 (possibly not the case on inlines, can't quite remember)
Anything with a factory overdrive (rare and weak unit, only on 250 and 283/307 motors) got the 4.10 (possibly 4.11)
small block with auto got a 3.07
I *think* big block with a 3 speed got 3.73... they only built a few. I know 3,07 came with the automatic with big block.
This is off my memory... but I think it is pretty close. A few years worked things a little odd, but these are the generic later year guidlines.
Also, there was then optional gearing. The same nubers as above, but for example if you wanted a small block with a 3.73 and an automatic...
There was talk a few years ago of some GMC trucks with 3.54 gearsets in a dana rear. I have never seen documentation of these in factory lit... but it seems they made a few. Consider this the exception, not the rule. If memory serves, they were in inline powered trucks.
