08-28-2003, 08:36 PM | #1 |
gaskets for tranfercase????
Does anyony know if a gasket / RTV is required on this transfer case? On the 8 pointed cover that is missing. it was leaking fluid and after taking it apart I found no seal/sealant.
08-28-2003, 08:45 PM | #2 |
We have used RTV on the plate and it works very well. You want to be careful not to have excess RTV get inside.
Jim |
08-28-2003, 08:52 PM | #3 |
Were there shims under the cover too?? My T 221 leaked bad, and I eliminated the shims, and it still fit tight to the case, so I used RTV sparingly and no more leak.
69 GMC K10 ..some restoration required....still.. |
08-28-2003, 11:28 PM | #4 |
RTV
You should have no problem with RTV but keep in mind many of the bolts in your trans case go through to oil and must be sealed. I have seen people change seals when the problem is the leaking bolts.
71 k/20 GMC 79 k/10 GMC 96 k/10 GMC |
08-29-2003, 06:33 PM | #5 |
I found no shims under this cover. Thanks for all the help.
