Old 12-20-2011, 12:23 PM   #1
FLcustom10
Lifter Retainer Ring?
I don't know if that's the correct name for it, but you can see in one picture it has fallen to the bottom, and in another I'm holding it part way up with my finger. What are the consequences of this and how expensive is it to repair?
FLcustom10 is offline   Reply With Quote
Old 12-20-2011, 12:33 PM   #2
hjewell2
hjewell2's Avatar
Re: Lifter Retainer Ring?
Oh my that needs attention. needs to be replaced. Those are the stock oil deflecters. I dare say you have metal shavings floating about.
hjewell2 is offline   Reply With Quote
Old 12-20-2011, 02:48 PM   #3
FLcustom10
How hard is it to replace? Or could I just go with something like this since I have tall valve covers?
http://www.summitracing.com/parts/MOR-67700/?rtype=10
Old 12-20-2011, 03:05 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Are my eyes playing tricks on me or are there two different versions of retainers here, look at the springs to either side of the failed one....
What engine is this we are looking at?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-20-2011, 03:11 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
To replace you would set that piston to TDC, remove the rocker arm, fill the cylinder with compressed air, use a vavle spring compressor to remove the part and then just put everything back together. Not a horrible job, but does require a special tool, compressor and fitting to put compressed air in the cylinder. (there's a video on youtube you can watch too)
The issue of possible shavings in the oil should be looked at as well, so an oil change and inspection of the filter is in order.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-20-2011, 04:27 PM   #6
FLcustom10
Thanks guys.
RenoKeene it's a 307, and it's possible that there are different versions. I'm not sure I'm seeing what you are seeing, and it could just be the angle, but it did have a broken timing chain and some repair work for that many years ago.
Do I need to avoid cranking this up until it is repaired?
Old 12-20-2011, 05:38 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
I would fix it if it were mine before I fired it up. And change the oil. I would also get a magnetic drain plug to catch whatever metal is floating around in there.
Old 12-20-2011, 10:43 PM   #8
hayhauler71
hayhauler71's Avatar
On the exhaust valve spring the retainers have rotators that turn the valve each time it opens. Used on 1973 or later heads and the exhaust valves would have hardened seats
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 12-21-2011, 12:28 AM   #9
GRX
GRX's Avatar
Agreed. I would fix that & remove the shards before firing it up. And check that valve/rocker assembly closely to make sure something didn't cause that deflector to break.
As hayhauler71 said, those are rotating retainers on the exhaust. As a side note ... for the 1st couple years Chevy used shorter exhaust springs to accommodate the thicker retainers, until the machines were re-tooled cutting the spring seats lower allowing all springs to be the same.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 12-23-2011, 06:24 PM   #10
FLcustom10
Thanks guys. Got it replaced. I think it's probably been that way for a long time and through many oil changes, but I'll do a couple of more oil changes to be sure.
Old 12-23-2011, 07:06 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Awesome, you did it yourself! I didn't realize how clean your engine bay was in the other pics...nice!
You say it was like that for a long time...wasn't it pretty noisy? Never had this happen, so I wouldn't know...
1970 2wd Blazer
Old 12-23-2011, 07:55 PM   #12
FLcustom10
Thanks! I didn't really do it myself. I had a mechanic friend come over and I 'assisted'. He let me do a lot of it though. I really don't know how long it's been like that and it's been sitting for the past 6 years. I've been working on restoring it for about the past year. Here's a link to the first test drive last week, just before I discovered the problem. I only discovered it because the valve cover gasket was torn and leaking a bit, so I noticed it when I replaced the gasket. I thought it sounded OK.
http://www.youtube.com/watch?v=MqiRp...ature=youtu.be
