07-27-2010, 12:48 AM | #1 |
DJM 3" spindles and 15" wheels
I have 15" corvette rally wheels in 5x5 pattern and installed DJM 3" drop spindles. I have a clearance issue with the top caliper mount. It rubs the inside of the wheel. Has anyone else had a similar problem? Can it be ground down just a bit or do you need larger rims?
07-27-2010, 01:56 AM | #2 |
Re: DJM 3" spindles and 15" wheels
Grounding down will fix it no problem.
07-27-2010, 04:39 AM | #3 |
i had the same problen on my truck!i just took a good ol' grinder and made it fit!!and a wheel spacer!!bt yes bigger rimms are the way to go!!
07-27-2010, 07:32 AM | #4 |
I've had to grind down the top of all the DJM spindles I've used. Take a little off at a time until the wheel fits. It won't hurt a thing.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
07-27-2010, 10:00 AM | #5 |
I'll give it a try later tonight. Thanks for the input.
07-27-2010, 10:31 AM | #6 |
I am using a 15x6 wheel in the front will this interfere with a drop spindle?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
07-27-2010, 07:47 PM | #7 |
07-27-2010, 11:47 PM | #8 |
I ground it until I didn't feel comfortable. So I got some 20's on craigslist. problems solved. I just told the wife that I needed new wheels to make my truck work...
11-01-2011, 06:53 PM | #9 |
Sorry to di, but anyone have pics on how far they went?
11-01-2011, 07:19 PM | #10 |
There's plenty of material to grind. I can't believe you don't have a clearance issue with the lower a-arm, or maybe you just haven't found it yet.
11-01-2011, 09:59 PM | #11 |
chevy runs deep
post pics when done
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
11-02-2011, 03:27 AM | #12 |
I keep hearing everyone talking about the lower a arm clearance with dropping these trucks. I've lowered 4 of them with djm spindles and different drop coils with multiple 15x 7 and 15 x8 Inch wheels and never ran into this problem. I have had to grind some meat off them to clear a wack set of aluminum wheels though.
Posted via Mobile Device |
11-02-2011, 08:46 AM | #13 |
6.0 powered square
My 7" cragar stars with 4 1/8 bs didn't have any trouble with 3" spindles, but when added wilwood d-52 calipers I had all kinds of problems so now I will be running 15x7 88-98 steel wheels for now till I can afford some 17 or 18 TT2s
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
11-02-2011, 03:03 PM | #14 | |
I have a truck with litterally no front suspension, so still trying to piece it together, research, to avoid any issues this weekend |
12-24-2011, 12:02 AM | #15 | |
12-24-2011, 12:28 AM | #16 | |
I would like to see some pictures of your truck after you lower it. I have the same wheels to put on after I lower it. At least until I can save up for 20's. Curious what it looks like. |
12-24-2011, 12:32 AM | #17 |
What tubular arms are those? Dont see them in google. How much were they? Cheapest I've seen are like $400!
'87 R10 - 5.3, 4.8 Flat Top Pistons, 220r Cam, Long Tubes, P&P 862 Heads, 4L80e '84 C10 - 5.3, LS6 Cam, 4L80E, 3.73, Ported Heads 329hp/334tq !! STOLEN !! 2-15-13 North AL Click Here:How To DIY Port & Polish LSx Heads Videso by "AGearHead4Life" |
12-24-2011, 11:10 AM | #18 | |
Happy to be here
1973-1987 Chevy C10 - StrongArms Front Upper-$400.00 1973-1987 Chevy C10 - StrongArms Front Lower-$600.00
