Old 12-25-2011, 01:38 PM   #1
SCOTI
SCOTI's Avatar
Re: Need help with wheel size.
A 245-60 on an 8" wheel up front would be about the same height (245-60 = 26.57"; 295-50 = 26.61").
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-25-2011, 02:01 PM   #2
Cue-Ball
Cue-Ball's Avatar
It's true that a 245/60 is about the same sidewall height as a 295/50, but both of those tires are considerably smaller than the stock 235/75 (28.9" tall).
Personally, I wouldn't even consider shortening the sidewall like that without dropping the truck a lot further. The shorter sidewall increases the distance between the tire and the wheel lip. So, dropping two inches but then putting on a tire that's 2.5" shorter is going to make the wheel gap nearly the same. In addition, a shorter sidewall creates an optical illusion; the smaller sidewall makes the wheel gap look larger. And even though you're only lowering the suspension 2", you're lowering the body of the truck by over 3". So, you're losing quite a bit of ground clearance but the truck won't really appear to be that much lower.
Sidewalls that short really need a lot more drop to look good, IMO. I think you're going to need something more in the range of a 5/6 drop for it to look right.
Cue-Ball is offline   Reply With Quote
Old 12-26-2011, 02:36 AM   #3
SCOTI
SCOTI's Avatar
I was trying to keep my personal preferences out of it since they were not asked for....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-26-2011, 03:32 AM   #4
Cue-Ball
Cue-Ball's Avatar
And I was trying to warn the guy that he might not end up with the results he expects, and possibly save him from doing the job twice.
Old 12-26-2011, 03:43 AM   #5
SCOTI
SCOTI's Avatar
I just went w/what he stated.....
Originally Posted by busfreak
I for sure want to put a 295/50/15 on a 10 inch wheel on the rear but I dont know what size to put in the front.
While you & I wouldn't do a set-up like this for the reasons you stated, plenty of other guys on this site would.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
