Re: VDO cluster
i'm guessing the vdo gauges are cheaper than the autometers? Where do you find VDO's anyways. I also know them from my old VW's
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: VDO cluster
These came from Summit.They are a real quality gauge/sender.Not sure how they compare to others in price.They dont use a bracket system for mounting,there is a large plastic ring{like a nut}that threads onto the whole gauge housing.Its all I have used for awhile now and not sure how everything else is mounted.The speedometer is pretty slick the way its calabrated,you just hit a reset button go a true measured mile,hit the button again and you are calabrated{checked with gps,its right on}.
