Old 08-30-2003, 02:25 PM   #1
western star
western star's Avatar
Shifter clearance for speedo question.
I put a Hurst Indy floor shifter in (3 speed ) and the main part of the shifter is about 2 inches away from where the speedo cable attaches to the trans. I don't have the room to hook it up and even if I did the cable would be right in the centre of the shifter itself. Why would Hurst make something that would eleminate your speedometer? Or is there something else like an elbow gear that I need and if so where can I get this. I am saving up for a good 4 speed right now but it would be nice to have a speedo. Thanks....
western star is offline   Reply With Quote
Old 08-30-2003, 02:33 PM   #2
jef5150
Inline 69
jef5150's Avatar
cant you re-install the shifter mounting plate a couple inches forward or backwards from where it sits in your opening???
jef5150 is offline   Reply With Quote
Old 08-30-2003, 02:42 PM   #3
western star
Good thought I'll check and get back to you. I just used the only holes supplied.
Old 08-30-2003, 02:51 PM   #4
jef5150
Inline 69
jef5150's Avatar
you might be limited there,on slot size on your linkage rods......did you get universal rods w/kit
Old 08-30-2003, 03:13 PM   #5
western star
I just had a close look at it and it would have to be move forward about 3 inches which would put the shift linkage at a pretty steep upward angle. The linkage is universal for many instalations but the instuctions suck big time. Right know it shifts real nice. I know the 70's and 80's GM trucks had a 90 degree bend adapter on the autos. If I can find one of them it may work.
Old 08-30-2003, 03:24 PM   #6
jef5150
Inline 69
jef5150's Avatar
http://www.sswhiteauto.com/products/ratio/right.html these?,,,
Old 08-30-2003, 03:29 PM   #7
western star
Ya that would work.
Old 08-30-2003, 04:12 PM   #8
ckenwright
ckenwright's Avatar
I have been looking for something like this for about 5 years now. Thanks
ckenwright is offline   Reply With Quote
Old 08-30-2003, 05:16 PM   #9
jef5150
Inline 69
jef5150's Avatar
that'll be $1.00......and as always, thank-you for shopping with us,,,,,lol..... jeff
Old 08-30-2003, 05:41 PM   #10
Western Star....I was confused about mine when I first put it in. matter of fact I broke a speedo cable bending it too tight to fix. Hope you can see in the pictures. First set it to mount as far forwar (to the front as you can). Then you run the speedo cable just in fron of the downward shifting arms. It looks like they will hit it when you shift to 1st or 3rd, but they clear.
I don't think this will matter much, but when I replaced my speedometer cable I got the longest stock size available. Gave me a bit more to play with.
It does look wired until you get it in, but she worked great fro me.
Only thing I would recommend is using loctite or a lock nut on the bolts that hold the shifter to the linkage. Mine worked loose after about 6-8 months.
Old 08-30-2003, 05:43 PM   #11
Sorry about the above shot...forgot to rotate it when I resized it. These next two pics show how it was mounted. Least for me it took a while to figure out exactly where I was to mount it. I'm not real quick on the first time with these things sometimes.
Old 08-30-2003, 05:44 PM   #12
Hope they help. I love my floor shifter. Way so much nicer than the 3 on the tree.
Old 08-30-2003, 06:12 PM   #13
western star
Bill thank you very much. The pictures are perfect and I understand exactly how it work now. The check is in the mail.
Old 08-30-2003, 06:16 PM   #14
western star
Oh ya my cable is long enough. All I have to do is back the clamp off from the frame and create a little more slack.
Old 08-30-2003, 07:58 PM   #15
Glad to be of assistance
Old 08-30-2003, 08:25 PM   #16
western star
I found out that the hole that was in the bracket was to far forward and the one at the back made the shifter sit way to close to the bench seat so I split the difference and drilled a new hole and everything works great. Ta Duh and a drum roll. Thanks again...
