T Case
How would you determine if the T Case needs to be rebuilt? This is a Rockwell 221, and rebuilding looks pricey so I want to make an informed decision here.
Grease Monkey
Re: T Case
For starters, If its not working or makes awful noises.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Re: T Case
It didn't seem to be too bad (last time I drove it anyway). The only thing that I remember being an issue is that it would pop out of 2WD. My grandpa just had a bungy cord holding it in
I'm not sure if that was just an adjustment item or an indication of an issue.
![]() Join Date: May 2007
Re: T Case
Upgrade to a np205.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Jan 2010
Re: T Case
I just upgraded my T221 to a NP205 and it wasnt that difficult. I rebuild the trans and the only hard part was getting the heavy trans and TC back in by myself. Very doable. You will need new drive shafts.
Re: T Case
the popping out of 2WD, would be a spring that is worn out. You are correct, rebuildling a 221 will get expensive. I liked mine much more than the NP205 I'm running now.
That being said, I had to fab a new cross member for the carrier bearing, and shorten the rear drive shaft, when I converted to the 205. IIRC, the front d/s will be OK.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
Re: T Case
I have 2 221's. One that worked fine in my truck and a parts donor. If you can describe what you need I can pull it from one or the other. They are going to the scrape yard soon.
Posted via Mobile Device |
Re: T Case
I'm not even sure what to look for to know what I would need.
Re: T Case
Okay, so I've torn it down just a bit. Can anyone tell me if you think this is worth rebuilding based upon what you see?
Bearing was destroyed. |
Re: T Case
Well, after looking at this a bit more it seems like the input shaft probably needs to be replaced. I'm not sure if I'm going to rebuild this case or try and find me a 205.
Re: T Case
Time to cut your losses and move on.
Re: T Case
I have parts if you need them. Scraping 2 case in the next week or so.
#13 | |
Re: T Case
| Bookmarks |
