Old 12-26-2011, 11:31 PM   #1
rich67
rich67's Avatar
cab mount bushings
maybe you guys can help a dummy. just opened a cab mount bushing set that i recieved with a truck purchase. it has two 3" bushings, two 2 1/2". two 1". two 3/4". then four what i believe to be bottom rubbers. and hardware which i believe is short 4 bolts. only 2 in kit. kit has no instructions with. getting ready to put front end on my gmc antrying to figure which ones to use. also cab is on truck already and has a 2" lift. im thinking i'll have to either find some 2" spacers or refab 2 1/2s. then use correct front mounts out of kit. anyone know what the correct front ones are? gonna try to load pics tomoro. any help appreciated, rich sorry such a long read.
rich67 is offline   Reply With Quote
Old 12-27-2011, 12:48 AM   #2
70cst
70cst's Avatar
Re: cab mount bushings
Bump ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-27-2011, 12:16 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
What year GMC? If I remember right the taller bushings are for the rear of the cab.
The front clip bushing size depends on the year of your truck.
I don't have a picture of the instructions, sorry.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-27-2011, 01:08 PM   #4
dfwright
dfwright's Avatar
Check out the pictures in Bruce88's build thread, and see if that helps you sort the parts out.
It’s Just A Pickup, Post #446
I recommend reading the entire build, it's amazing the amount of information provided. I use his thread for reference all the time.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-28-2011, 01:20 PM   #5
rich67
rich67's Avatar
72 gmc 4x4.
Old 12-28-2011, 01:21 PM   #6
rich67
rich67's Avatar
thanx for the help folks. rich
Old 12-28-2011, 01:39 PM   #7
rich67
rich67's Avatar
thanx dude. i have some of those pieces but not all. need to get pics loaded of mine. says its for all 67-72 1/2, 3/4, 2wd, 4wd. only two metal spacers in my kit.
Old 12-28-2011, 03:23 PM   #8
ChevyGearHeads
SRV profile pic man too cool
ChevyGearHeads is offline   Reply With Quote
Old 12-28-2011, 05:29 PM   #9
rich67
rich67's Avatar
[/IMG]
Old 12-28-2011, 05:31 PM   #10
rich67
rich67's Avatar
thanx. one of my favorites.
Old 12-28-2011, 06:25 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
Cab bushings are different from 1/2 T and 3/4 or 4wd. The rear cab mounts on a 3/4T and 4wd are lower on the frame than 1/2T 2wd to allow for a thicker rubber bushing to give a smoother cab ride.
Old 12-29-2011, 03:17 AM   #12
rich67
rich67's Avatar
maybe that is why there are so many. to cover all models.
