Old 12-24-2011, 07:12 PM   #101
longbed67
longbed67's Avatar
Re: Project: Turbo 250
and the final one for the day.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 12-24-2011, 08:06 PM   #102
Hart_Rod
Hart_Rod's Avatar
Cool build....!!!!
Hart_Rod is offline   Reply With Quote
Old 12-26-2011, 03:35 AM   #103
70c-10
nice build!
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 12-27-2011, 12:09 AM   #104
slick copper
slick copper's Avatar
Nice work so far! I wanna see that intake!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 12-28-2011, 02:37 AM   #105
longbed67
longbed67's Avatar
As you requested Raymond, however I still have some polishing to do, a little touch up with the semi gloss black, and then a final clear. But other wise I think you get the picture of what she'll look like.
Adam
(608) 214-8706
Old 12-28-2011, 02:43 AM   #106
longbed67
longbed67's Avatar
So got a bunch done today.... Sway bar is installed just have to get longer bolts for the front and tighten it down. I got the compressor, tank, manifold/valve box, and manifold/valve assembly test fitted and mocked up. I started bending the air lines and will get everything test fitted and then I will tear it all apart again polish everything again, and then reassemble!
Adam
(608) 214-8706
Old 12-28-2011, 02:45 AM   #107
longbed67
longbed67's Avatar
Angle shot of the lines coming through the frame and into the box.
Adam
(608) 214-8706
Old 12-28-2011, 02:47 AM   #108
longbed67
longbed67's Avatar
Lines coming into the box. I dont really need this box as the valves are weather and water proof but I think with all the plumbing and wiring it will look cleaner tucked away.
Adam
(608) 214-8706
Old 12-28-2011, 02:48 AM   #109
longbed67
longbed67's Avatar
I got the new corvette master cylinder painted and mocked up today too, so I can start bending new brake lines for the truck as well!
Adam
(608) 214-8706
Old 12-28-2011, 06:18 AM   #110
slick copper
Nice! Yeah, I definately think that was the way to go. So you're gonna clear over the whole thing? I guess that'd make it much easier to clean later and keep from polishing all the time?
Good work on the air setup too. I agree and think that box will clean it up underneath too. Plus give a little added protection. Coming along nicely.
This gonna be a show truck when you're done?
Raymond
Old 12-28-2011, 11:58 AM   #111
67cheby
67cheby
67cheby's Avatar
great progress, looking good
67cheby is offline   Reply With Quote
Old 12-28-2011, 06:31 PM   #112
longbed67
longbed67's Avatar
It will be of show truck quality but it will be my daily driver during the months that dont have snow and salt. I have been building high performance setups for other people since I was 16 and it is finally my turn to build something for myself!
Adam
(608) 214-8706
Old 12-29-2011, 03:34 AM   #113
slick copper
Cool! Always nice to get to do something for yourself. Sounds like you have the same kinda idea I have to use my truck for when I get it done. Doesn't have to be perfect, but nice enough you can shine it up and take to a cruise in or show and be proud of it.
Also what kinda brake setup are you going with? You said corvette master cylinder. Are you not running power brakes? Disc/Drum, Disc/Disc? Just curious. I may have missed it somewhere else though.
Raymond
Old 12-30-2011, 05:32 AM   #114
longbed67
longbed67's Avatar
No power brakes for me. At least not for now. I wasn't sure if I would have room to run a booster or a hydraulic setup with the turbo, so I just went with standard brakes. I am not a huge fan of the squishy pedal feel of power brakes as compared to standard brakes either. I definitely am running 4 corner discs with drilled and slotted rotors. And according to the parts store I am running the 1 ton calipers up front which have the 3-3/8" piston instead of the 2 and something piston. 1/4" brake lines all around.
Adam
(608) 214-8706
Old 12-30-2011, 09:54 AM   #115
hgs_notes
GEARHEAD
hgs_notes's Avatar
I have a 3/4 ton booster on my brakes (disc/drum) and there is definitely NO squishy feel. They grab hard enough that I had to relearn to drive it without jerking to a stop. It is easy enough to add later though once you see what room you have.
hgs_notes is offline   Reply With Quote
Old 12-30-2011, 10:59 AM   #116
longbed67
longbed67's Avatar
hgs, are you running 4 corner disc? and what do you mean by a 3/4 booster? I was just basing it on my experience when we switched out my buddies 56 chevy 210 over to power brakes and another buddies 53 chevy 3100 over they both grabbed hard but the pedal was just a little squishy...
Adam
(608) 214-8706
Old 12-30-2011, 11:10 AM   #117
hgs_notes
GEARHEAD
hgs_notes's Avatar
edited earlier post. I planned on doing disc rears but there really is no need for it the way I drive it. Thing to remember is that these trucks are relatively light by todays standards. Mine weighs about 4000 lbs which is actually less than my dd taurus, and way less than my wifes denali xl. Unless I start doing autocross, my brakes are good as is. The switch to power brakes was well worth the cost though. Can't even compare with non-power for pedal effort and stopping distance.
Old 01-10-2012, 11:45 PM   #118
longbed67
longbed67's Avatar
Not to much to update other than I got the rest of my electronics in for the methanol injection system from germany. I am getting ancy to pick up my short block from the machine shop as he gave me an update that everything was going on track! Also if anyone has a set of the front sway bar brackets and are interested in selling them pm me I need a set Thanks
Adam
(608) 214-8706
Old 02-05-2012, 12:01 AM   #119
longbed67
longbed67's Avatar
So, I got back from my clinical rotation, and expected my engine work to be done and the head work done, but no such luck, so I decided to go ahead and start the body work. I got the cab flipped on its back stripped the bottom. I will get it cleaned and prepped for an epoxy sealer Tomorrow, and then will be shooting Keystone bedliner on the bottom with single stage paint mixed with it so it match nearly exactly with the BC/CC that I shoot on the rest of truck this next week.
Adam
(608) 214-8706
Old 02-05-2012, 04:51 AM   #120
slick copper
That sucks on the engine, but sounds like a cool idea on the cab. We need pics!
Raymond
Old 02-08-2012, 09:34 AM   #121
longbed67
longbed67's Avatar
I LOVE my soon to be mother in law!!!! So my fiance didnt want to use the 67 in our wedding (8/17/13) it will be long done by then. And I have been telling her since I got it that we would be using it. And yesterday without any preempting on my part my mother in law to be says quote " You know what would be really cool, if Adam has his old truck done before the wedding and you guys could drive away in that!" I about did a back flip! So she turns around and tells me alright we will use your truck!!!!
more pics will be coming later today after I get the paint and bedliner sprayed on the bottom.....
Adam
(608) 214-8706
Old 02-08-2012, 10:25 AM   #122
67cheby
67cheby
67cheby's Avatar
now you can " yes honey i have to have that part....i am trying to get this done for the wedding " WINNING !!!
Old 02-08-2012, 12:40 PM   #123
longbed67
longbed67's Avatar
So I got it painted now to wait 6 hours per KBS Coatings till I can top coat with the spray on bedliner... The center was not painted because I will be cutting that out for the high hump to get bolted in.
Adam
(608) 214-8706
Old 02-08-2012, 06:33 PM   #124
longbed67
longbed67's Avatar
So I got the bedliner sprayed on the bottom.... I like it and hopefully it will be one more barrier against sound and future rust... And because it is tintable using the single stage without the clear added in the same color as the rest of the truck will be painted it will blend nicely
Adam
(608) 214-8706
Old 02-08-2012, 06:37 PM   #125
longbed67
longbed67's Avatar
And look what showed up while I was spraying! my Class 4 hitch!!!! I would start installing it but I just realized I dont have rear sport bumper brackets to mount the bumper to line it up so I know where to drill my holes
Adam
(608) 214-8706
