Old 12-30-2011, 01:29 PM   #1076
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
BTW, I showed the POR15 can so you can see my method for opening and resealing with two screws. I never remove the lid. Works awesome.
Frizzle Fry is offline   Reply With Quote
Old 12-30-2011, 02:36 PM   #1077
OLDIRON69
just opening the can is like disarming a bomb...VERY VERY careful!!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 12-30-2011, 06:02 PM   #1078
BlueJeep
BlueJeep's Avatar
Seems like a good idea, the only question I have is POR recommends stirring before every use, what's your innovative solution for that (asking because I know you have one )?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-30-2011, 09:37 PM   #1079
Frizzle Fry
Shake it up in the can and stir the portion you put in another container.
Old 12-30-2011, 10:05 PM   #1080
mcbassin
Still Learning
mcbassin's Avatar
I've never used any POR products. I understand it's Paint Over Rust right? So, I'm wondering how well it adheres to bare metal? I know you said you scuffed it good. How durable is this stuff? I have been using rusteoleum products on my frame and it scratches pretty easy. I think it's acrylic enamel?
I assume that stuff is pretty thin too if you can pore it out of a screw hole? Keep up the pictures and great information.
Old 01-05-2012, 02:46 PM   #1081
Ackattack
Ackattack's Avatar
My old boss (who sells POR15 on the side....he's into Studebakers) told me the same method. Seems to work good.
Ackattack is offline   Reply With Quote
Old 01-15-2012, 07:05 PM   #1082
Frizzle Fry
Started bending up brake lines (no pics just yet). Came to the conclusion that a decent double flare tool will be more than justified for this project, not to mention future use. So I have the Rigid 345-DL kit on the way.
With the brake system on the mind, I ordered an adjustable prop valve which will be mounted for cockpit accessibility.
Also ordered the POR-15 fuel tank seal kit. Since I did weld on it I figured better now than later after being stranded by a clogged fuel filter...
Old 01-17-2012, 10:53 AM   #1083
OLDIRON69
I think that is the most logical place for a machine like this!!!
05 2500HD 6.0 excab
Old 01-17-2012, 06:27 PM   #1084
Zumo
Hot Rods For Life
Zumo's Avatar
I can't believe I am just now finding this build thread. This is one of the most impressive build I have seen. I have always thought the S2000 motor would be a good donor for any rear wheel small car. I commend you on your work. Wow.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 01-19-2012, 04:33 AM   #1085
Frizzle Fry
It is decided
Thanks Zumo. Should make for a fun commute. Maybe we'll have to do a rendering when its done
Old 01-19-2012, 05:23 AM   #1086
y5mgisi
Second Chance Program
y5mgisi's Avatar
Very ambitious project! More than im willing to tackle!
y5mgisi is offline   Reply With Quote
Old 01-19-2012, 09:07 AM   #1087
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
isn't a rendering supposed to be for BEFORE you build it?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-21-2012, 02:16 AM   #1088
Frizzle Fry
Yeh, sometimes the eyes are bigger than the stomach
That would be the "normal" order of events, yes
Old 01-30-2012, 01:22 AM   #1089
Frizzle Fry
We left off with the rear painted. So lets do a before and after:
Before-
After-
Moved on to the brake lines:
Starting with the rear-
Picked up a double flare tool for the project-
MC's on down (camera is goin south)-
Front line to T-
First (and only) T in front circuit ...and across to the pass-side (avoiding exhaust)-
DS Front-
Old 01-30-2012, 09:41 AM   #1090
spudz
spudz's Avatar
Very clean. Where did you get the coil the goes over the brake lines like the factory use?
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-30-2012, 12:59 PM   #1091
Frizzle Fry
Thanks. I stole them from some lines on a C5 Vette chassis. But I know inline tube carries them.
Old 01-30-2012, 01:35 PM   #1092
watahyahknow
watahyahknow's Avatar
thanks for the tip , they have stainless brakelines too
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-30-2012, 01:39 PM   #1093
Frizzle Fry
Yes they do. I'd probably use it on a street rod type build. The poly-armor lines are sweet though. So easy to work with.
Old 01-30-2012, 02:26 PM   #1094
mcbassin
Still Learning
mcbassin's Avatar
Rear Diff and brake lines look great! You are the man.
Old 01-30-2012, 07:12 PM   #1095
68 Four on the Floor
68 Four on the Floor's Avatar
You are way more ambitious than I ever will be
68 Four on the Floor is offline   Reply With Quote
Old 01-30-2012, 11:54 PM   #1096
Jvsapp
Jvsapp's Avatar
damn FF, how do you bend your lines so clean? what benders are you using? Also no combination valve? or is that the adjustable one you ordered? i thought they had individual lines for the left and right front wheels? i'm looking for some fittings to do a 90 on my nova. any ideas where i could get some?
now you have me thinking i want to POR15 my nova's rearend. i was just going to hit it with rustoleum but now i'm sold! POR15 it is...
Jvsapp is offline   Reply With Quote
Old 01-31-2012, 02:16 AM   #1097
Frizzle Fry
If I had known it would take 3yrs I'm not sure I would have been so ambitious
Brake lines:
I have a no name 180* bender. But for some of the bends I just did it by hand as shown in the vid.
I have an adjustable prop valve installed (will post pics). It's mounted for on-the-fly accessibility.
Looking for something like this?
http://www.discounthydraulichose.com...bow_p/3502.htm
The S2000 MC has front and rear circuits that are split out to left and right by the ABS unit that I have deleted.
Old 01-31-2012, 02:33 AM   #1098
Jvsapp
Jvsapp's Avatar
ahh that AGS i can get from checker..... i've actually used it and it bends nicely. i guess that's what i'll be using on my nova when i do the front brakes.
thanks for the link for the fittings! i guess i'll be looking for some that i can clip in now.
Old 01-31-2012, 03:17 AM   #1099
Frizzle Fry
Yep, I jump around a bit... I had the front Xmember in for checking brake line routing:
So while it was in, there was something that needed to be completed ...the shortening the front sway bar brackets. So in maintaining the theme of modifying (nearly) every part of the this car:
We'll start with the original bracket shot-
New bolt holes raised 1"
Remove blind-nuts:
Clean-up:
Welded the nuts back on 1" higher and...
Why I felt the need to raise the bar (see right orig vs. left raised)
Side shot of modded bracket ("gusset" also clearanced) Yes the mount plate is still just tacked in...
x2 (those scraps actually came from what is the top in this pic)
Old 01-31-2012, 03:26 AM   #1100
Frizzle Fry
Clutch line and rear brakes to prop valve (clutch will have a bracket for the flex line)
Zoom on prop valve (inside shot disappeared in the shuffle... it's next to the ebrake)
