Old 01-02-2012, 12:23 AM   #1
bigtruckboi2000
bigtruckboi2000's Avatar
Will it fit?
Will a Edlebrock Performer manifold(part # EDL-2101) fit on my 350 SBC? I wanna use it to replace the Torquer II that's on it now and getting a real good deal on it. Here are some details on it-Edlebrock Performer Chevrolet Small Block Intake Manifold, Quadrajet flange & EGR Block. I have a Edlebrock 1406 600 cfm on it.
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears
2005 GMC Yukon XL Denali w/Mangnaflow Exhaust
1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters
Patriots always talk of dying for their country but never of killing for their country.
bigtruckboi2000 is offline   Reply With Quote
Old 01-02-2012, 12:28 AM   #2
NCD1966
NCD1966's Avatar
Re: Will it fit?
Edelbrock 2101 Performer Series Intake Manifold
Fits 1955-1986, Chevrolet 262-400 cu. in. non-EGR V8s
check to see if your heads are 86 and older
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 01-02-2012, 12:43 AM   #3
bigtruckboi2000
Re: Will it fit?
The plan is to run Dart heads(part # DRT-127221, summitt racing) with the performer manifold. The heads on the engine now are 305 heads(80-86 era) that are coming off once I get the dart heads and the performer manifold. The block is a standard 350 from the 68-79 era.
Old 01-02-2012, 01:51 AM   #4
Captainfab
60-66 Nut
Re: Will it fit?
Yes it will bolt up to either heads.
Old 01-02-2012, 08:47 AM   #5
bigtruckboi2000
Re: Will it fit?
Will i need or have to change the carb? And what is EGR?
Old 01-02-2012, 09:04 AM   #6
NCD1966
NCD1966's Avatar
Re: Will it fit?
dont worry about EGR, sounds like you dont have it. exhaust gas recirculation, its a emission device that recirciates exhaust gas back into the engine.
Old 01-02-2012, 10:10 AM   #7
Rich 5150 69
Rich 5150 69's Avatar
Re: Will it fit?
This is where you need to decide either quadrajet or elde carb, one is a spread bore the other eldbrock is square bore carb..get the correct manifold/carb.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-02-2012, 10:22 AM   #8
bigtruckboi2000
Re: Will it fit?
IMMA keep the edle 1406 carb to put on it. Will the performer be an improvement over the torker II 5001 that's on it now?
Old 01-02-2012, 10:52 AM   #9
NCD1966
NCD1966's Avatar
Re: Will it fit?
the Torker II is a single plane manifold and the Edelbrock Performer is a dual plane. A dual plane intake has a lower power band than a single plane. So if your looking for more low end power, this performer will help you in that department.
Torker II power band is 2,500-6,500 rpm
Performers power band is Idle-5,500 rpm
if you have a stock to mild cam you want the performer intake
Old 01-02-2012, 11:32 AM   #10
bigtruckboi2000
Re: Will it fit?
So the performer manifold it is. Thanks guys, your knowledge is invaluable!!!!
