Closed Thread
Old 01-01-2012, 01:14 AM   #4451
XtechX
XtechX's Avatar
Re: What did you do to your truck today?
Originally Posted by padresag View Post
I hope that they are dry
ron
Yes, nice and dry. I thought it was a real reasonable deal on the wood. I cut all the grooves etc in them today. They turned out very nice, but I didn't go the full 1/4 inch wide for the grooves (about 3/16").
Opportunity usually comes disguised....As hard work!!!
XtechX is offline
Old 01-01-2012, 02:13 AM   #4452
oem4me
Originally Posted by XtechX View Post
I went to a local saw mill and picked up 10 3/4" white oak boards for my bed floor for $120 bucks. They were all planed and trued up and ready to cut to size. I cut them to spec according gmcpauls write up, or as close as I could. Now I have to cut the grooves etc in them. I made some practice cuts on some scrap, using just a regular combination blade, anyone else just use a regular blade to cut the grooves? Did you go the full 1/4" wide?
White oak is a great choice in wood, and particularly beautiful if the annual growth rings are perpendicular to the board face (quartersawn). There is no reason you can't make the required grooves with a standard blade. Just make a pass and move the fence over a tad for another pass until the groove is as wide as it needs to be. You'll be pushing the planks over the saw many times each, but it'll work.
oem4me is offline
Old 01-01-2012, 05:17 PM   #4453
towersddg9
towersddg9's Avatar
Originally Posted by 65Gregg View Post
Towesddg9 what did you use to change your centerbolt covers to perimeter style? Adaptors that bolt to the center bolt holes?
Trick Flow makes the kit, got it from summit, good stuff
towersddg9 is offline
Old 01-01-2012, 06:06 PM   #4454
Rich 5150 69
Rich 5150 69's Avatar
Not what I have done but more what needs to be done, replace heater core, it blew out Thursday morning on the way to work, its from radiator exspress, ( 55 plus tax vs 79 plus tax thru LMC ) they are the cold glue type, lasted eight years, not sure I want to go the glued route again. Mann it sured fogged up the interior in a hurry, could`ntt see anything at 4:00 am in the morning when the outside temp was 28 degees, had to open both windows to clear out....it was cold. Does anybody know if LMC`s are soldered or glued.....?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 01-01-2012, 06:40 PM   #4455
Turkey
Turkey's Avatar
Put 3" drop rear coils and shocks and also got my rear light harness put in and my lights put back together.
Turkey is offline
Old 01-01-2012, 07:53 PM   #4456
coulter
coulter's Avatar
put the engine in my truck today
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline
Old 01-01-2012, 08:03 PM   #4457
sandiego65
sandiego65's Avatar
NOTHING!New years day cleaning and taking apart cribs and moving furniture so my girlfriends sister could move out so much FUN. Could you sense my sarcasm!
sandiego65 is offline
Old 01-01-2012, 08:51 PM   #4458
rendus
rendus's Avatar
I went to bleed my brakes today and ended up with another blown brake line. Right rear portion just before the rubber brake hose. Pretty sure the rubber hose has collapsed so I ordered a new one from Ecklers.
'66 C10 250 3-on-the-tree
'68 Galaxie 460/C6
'74 914 2.0
rendus is offline
Old 01-01-2012, 09:52 PM   #4459
towersddg9
towersddg9's Avatar
put in a different wheel
Old 01-01-2012, 10:17 PM   #4460
Narxoleptic Customs
Got my new speakers mounted!! 6x9s baby!!
Narxoleptic Customs is offline
Old 01-02-2012, 12:10 AM   #4461
iceship
Console back to black
Could use new chrome trim but it's good for now..
iceship is offline
Old 01-02-2012, 01:54 AM   #4462
markeb01
Senior Enthusiast
markeb01's Avatar
Beautiful engine. Love the aluminum against the black.
markeb01 is offline
Old 01-02-2012, 08:53 AM   #4463
coulter
coulter's Avatar
thanx man... ive had the engine bay envisioned in my head forever.. im glad i finally got to see what its really gonna look like.. im gonna keep it as minimal as possible.. manual steering, manual brakes, a push electric fan on front of radiator, hide the wireing and brakelines .. eventually gonna replace all the bolts in the engine bay and on the motor with nice stainless ones to
coulter is offline
Old 01-02-2012, 12:13 PM   #4464
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Pro street truck is at the body shop so between my visits and work there....
I pulled my next project out of storage and put it into the front of the shop...Powder coated frame rolling chassis....washed it all up and looking it over to decide what changes i want to make...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 01-02-2012, 05:10 PM   #4465
csa daddy
csa daddy's Avatar
Put front chopped crossmember in truck an air bags
csa daddy is offline
Old 01-02-2012, 08:36 PM   #4466
doublebeetx
Csa, how did you "chop"your crossmember ? Does it move forward to center your front wheels in the wheelwell ?
doublebeetx is offline
Old 01-02-2012, 09:34 PM   #4467
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
I filled in my dash for A/C controls and vents. Also installed my rubber bed mat...
Before;
After;
Bed mat;
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline
Old 01-02-2012, 09:43 PM   #4468
Chvyman1975
Chvyman1975's Avatar
Today replaced the driverside bed panel. I picked up a shortbed about a month ago for $100. Well traded it for a 292 that I paid 100 for. Now need to decide on one piece of high quality plywood or a bed kit. Also got a gilmer drive kit. Need to find a different alt bracket for it to work.
Chvyman1975 is offline
Old 01-02-2012, 10:47 PM   #4469
jrisch
jrisch's Avatar
Started to remove the front end, to get ready to sand blast and then take in to the powder coater!! Smashed my hand with a hammer (not the smartest thing Ive done) so I thought I would call it a day
Name:  Jan  2012_03.jpg
1962 Chevrolet S/B Fleet side
Engine: 283 Transmission: 3 speed manual
2 do list !!!!!!
Frame off-2 1/2" front , 4" rear
Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood
jrisch is offline
Old 01-02-2012, 10:52 PM   #4470
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Washed the windows, filled her with gas, and kept on driving. Still loving driving her!
fryer1979 is offline
Old 01-02-2012, 11:12 PM   #4471
pdxhall
pdxhall's Avatar
Nothing on the truck but related. I picked up the gas cylinder for my new mig welder and began the learning process. I can't believe it took me 45 years to do this. I had a lot of fun, managed to get a half decent bead by the time I quit, and I didn't burn down the garage or burn or electrocute myself. It was a good day!!
pdxhall is offline
Old 01-02-2012, 11:27 PM   #4472
PORKY
PORKY's Avatar
Originally Posted by Alan's Classic View Post
Got my seats installed.
The seats look GRRRRRRRRRRRRRRRRRRRRReat! What did they come out of?
PORKY is offline
Old 01-02-2012, 11:37 PM   #4473
E911manager
Well not just today for over the last 2 "truck" days... Two coats of POR15 on the frame after cleaning it up with a pressure washer and wire brush and wire wheel. I also worked on the firewall. More pics on my build page...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 01-03-2012, 12:27 AM   #4474
ralf
Falk!! I typed two long posts and fat fingered them into the ether-sphere.
ralf is offline
Old 01-04-2012, 08:38 AM   #4475
iceship
Console not bolted down yet... have to wire the heated function going to mount under console....
iceship is offline
Closed Thread
