Old 12-27-2011, 10:36 PM   #1
peacock
Another newb motor mount question
Can someone help me find a thread or some plans for V8 conversion in 4.3 s-10 frame??? Or the best way to mount it in my 54/s10. Thanks in advance
peacock is offline   Reply With Quote
Old 12-28-2011, 09:39 AM   #2
63 & 64 Bowties
and a few others
Re: Another newb motor mount question
I know nobody wants to hear: "use the search function" so I won't do that to you, but looking at this page:
http://67-72chevytrucks.com/vboard/f...splay.php?f=13
near the top is the "Projects and Builds" sub-category. Scroll through the posts there and you'll see it's pretty easy to pick out who's doing S-10 swaps. You'll also see that there's no one answer to you question. It's been done several different ways. I'm sure you'll see a method that will work for you.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-28-2011, 02:12 PM   #3
peacock
Yeah I used the search and just about everything came up. Just was seeing if anybody had a good plan or method for it. I'll figure it out. Thanks tho
Old 12-28-2011, 04:04 PM   #4
OrrieG
OrrieG's Avatar
Bowtie is right, depends on your skill level. some like to figure it out and fab everything. others will buy a kit someelse has done. Look at sgtusmc build, turned out really nice and he did all the fab work himself.
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
Old 12-28-2011, 05:53 PM   #5
peacock
I fab all my own stuff but I was just wanting to look at different ideas and whats worked best or if there was a quicker route. Thanks
Old 01-01-2012, 10:23 AM   #6
63 & 64 Bowties
and a few others
I'm going with the method xpickup used on his 54.
S-10 swap mounts with the original 2436 motor mounts.
Basically, turn everything upside-down. The metal conversion mounts are used on the opposite side that they were made for. And you mount the 2436 rubber mounts directly to the engine block like a pre-69 Camaro. Then weld the S-10 bracket onto your K member.
This is xpickup's mounts:
and mine ready to go in:
Old 01-01-2012, 11:48 AM   #7
peacock
Thank you, that seems pretty quick and easy like I need. That's the 2.8 rubber mount?
Old 01-02-2012, 08:51 PM   #8
AD51
AD51's Avatar
This is the way I'm doing mine...
AD51 is offline   Reply With Quote
Old 01-02-2012, 09:02 PM   #9
peacock
Thanks AD, that looks exactly what I came up with first. I just used 1/8 plate just to see how it would be. Need to go get thicker plate and finalize it
Old 01-02-2012, 09:12 PM   #10
AD51
AD51's Avatar
Mine are 5"x8" 1/2" plate. drilled to the factory 4.3 locations using the back hole to mount the front hole in the frame mount. I need to drill and tap the back ones. Then regular 4.3 mounts will bolt to the small block and drop straight on the frame mounts.
Old 01-03-2012, 01:33 PM   #11
rollinrooster
rollinrooster's Avatar
Here are a few pics of mine sittin in the factory 4.3 location.
rollinrooster is offline   Reply With Quote
Old 01-03-2012, 01:44 PM   #12
xpickup
xpickup's Avatar
Hey I think I saw that picture before. I did it that way I did not have to tear the front end apart, plus I could set it back a little.
Shannon
xpickup is offline   Reply With Quote
