01-02-2012, 08:15 PM | #1 |
camaro front clip? or camaro?
i found a 77 lt camaro will this front clip work i dont know the cut off year for clips or i found a 74 nova witch is better ?
01-02-2012, 08:38 PM | #2 |
Re: camaro front clip? or camaro?
Camaro 70 to 79 all the same, it will work fine...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-02-2012, 09:25 PM | #3 |
yep, and it'll revolutionize the driving of your truck. here's a few pics of mine.
01-02-2012, 09:27 PM | #4 |
and no snide remarks about my leaky valve cover gasket. Fel-Pro blue stripe, lasted '85 to 2011. Not bad, IMO. fixed now. right side is still clean and dry. at least 200K on that engine.
01-02-2012, 09:31 PM | #5 |
That will work fine for the swap.
here is a link to a thread on the HAMB that Lux Blue did that has become one of the go to threads on this swap on the net. http://www.jalopyjournal.com/forum/s...d.php?t=148978 He walks you through it step by step and he has done a lot of them in his shop over the years. |
01-02-2012, 09:33 PM | #6 |
The Nova is 2 inchs narrower than the camaro,also Nova is rear steer camaro is front steer.
01-02-2012, 09:35 PM | #7 |
should mention, frame is plated inside back to about the cab mount.
part of the reason it drives good is the 1.125 front sway bar and the 12:1 WS-6 T/A steering box. Recent addition of C4 Vette rear really helped too. this thing drives like a go-kart. |
01-02-2012, 09:44 PM | #8 |
no shortage of opinions here. the early rear steer Nova clip AFAIK is the same as an 67-69 Camaro. Problem with these is that it has short spindles like a 64-72 Chevelle. This means the front roll center is several inches below ground level. The later Nova and Gen2 Camaro has a tall spindle design which places the roll center about 4" above ground level. Inherently better handling deal.
01-03-2012, 01:09 PM | #9 | |
Glad to see....
I jest can't stand no pristine, spottless trailer queen.... reminds me to much of my second wife..... justplainray |
01-03-2012, 08:46 PM | #10 |
I used for a mobile mechanic work truck for years, stoplight to stoplight in Phoenix in the summer. That's hard miles.
