Old 01-03-2012, 04:47 PM   #1
northeimcustom
northeimcustom's Avatar
front only bag question
i am thinking i am just going to put bags in right away since i have them laying around when i do brakes and drop spindles. i want to just have them on a schradder valve for now....
i have 1/2 lines and i need to know which fittings i should use and such....
northeimcustom is offline   Reply With Quote
Old 01-04-2012, 12:02 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: front only bag question
Nothing special for this really...just a 90 elbow off the bag so a line can go through the crossmember and to a location that's accessible where you schradder valve will be. Going from a 1/2" line to a schradder will just take some reducer/bushings.
I have 1/2" line in my blazer, and if I could do it all over again, I'd do 3/8...it's MUCH easier to route and the speed is nice...not too slow and not too fast.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-04-2012, 11:49 PM   #3
91Subbed
What set up are you using for the front? I wanna do a front only on my suburban. But can't find a list of parts That is needed. Can you help a brother out!
91Subbed is offline   Reply With Quote
Old 01-05-2012, 11:59 AM   #4
northeimcustom
i just have the cups plates and bags....
going to do drop spindles too while im all up in there
Old 01-05-2012, 12:04 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
We make a front kit that includes bags, shocks, mounting bracketry and hardware. We can also supply you with the schrader system if needed. Shoot me a PM with your number and I will give you a call to further discuss.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-05-2012, 12:09 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
As mentioned its pretty simple to do. With that said, I do not recommend it for the front. If you have a slow leak it can make it inoperable if the front tires set on the fender liners. at a minimum get a tank with a manual ball valve so you have a back up supply.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-05-2012, 01:04 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
Originally Posted by n2trux View Post
as mentioned its pretty simple to do. With that said, i do not recommend it for the front. If you have a slow leak it can make it inoperable if the front tires set on the fender liners. At a minimum get a tank with a manual ball valve so you have a back up supply.
x2!
1970 2wd Blazer
Old 01-05-2012, 03:55 PM   #8
91Subbed
What is a schrader valve system?
Old 01-05-2012, 04:35 PM   #9
DLOE65
DLOE65's Avatar
Check out my link below, I have some cool manual valves you might be interested in.
DLOE65 is offline   Reply With Quote
Old 01-05-2012, 07:27 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
You run the air line and fittings out of the bag, but instead of using a valve and onboard compressor/tank set-up there is a schrader valve at the end of the line (similar to the old school air shocks). You can fill with a shop compressor... just not on the fly. We use the schrader set-up on the projects in the shop. Many guys will run them on their finished project, as you get the ride quality and adjustability/tuning that a bag offers without all the expense of an air management. Great option for a "semi-static drop".
Dloe's valves are a nice affordable set-up as well. Great option for an adjustable set-up while staying within the budget.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-06-2012, 04:52 PM   #11
made2drag
made2drag's Avatar
i have the simplest ball valve setup in the world with the peice off a $20 air tank that has a schrader valve.
its holding me over til i get the $400 for 8 smc valves
heres my link....it works really well too
http://67-72chevytrucks.com/vboard/s...d.php?t=496829
made2drag is offline   Reply With Quote
Old 01-06-2012, 04:55 PM   #12
made2drag
made2drag's Avatar
also, i used a cig lighter type compressor until i mounted my viair 380. i still need alot of stuff still. you can go to o'rielly's or carquest and find a schrader valve fitting for like 3 dollars. i think they are 1/8 inch so go to lowes or hd and get some fittings to get you back up to 1/2
Old 01-09-2012, 02:44 PM   #13
91Subbed
What's the difference between single port and dual port air bags? I'm trying to put together a front set up. What kind/size of valves do I need? How bout the compressor size? Best airline size?
Thanks in advance for any input!
Old 01-09-2012, 03:00 PM   #14
tubbedII
needs more $$$
tubbedII's Avatar
Stick with a single port...duals are for fast baggers that are trying to hop and not necessary unless you're doing that (plus you'll need different mounts and such). For the rest, it'd be best to start your own thread so you hijack the OP's
1970 2wd Blazer
Old 01-09-2012, 03:14 PM   #15
DLOE65
DLOE65's Avatar
It all depends on what you are looking for in your system. Dual port bags were a fad when everyone wanted to hop there truck.. They are not needed. The tank size, valve and airline size along with the # of compressors is up to you and how much you think you will play with your airride.
Old 01-09-2012, 03:18 PM   #16
91Subbed
Ok so single port bags. I'm thinking just a weekend to toy. then I'll end up doing the back. But I wanna get the front going first
Old 01-09-2012, 03:22 PM   #17
91Subbed
Dloe65: could I use your Manuel valves with my set up?
Old 01-09-2012, 03:40 PM   #18
BuiltwithIvy
Theres a company called wheelsnparts that builds a pretty nice looking 8 valve manifold with valves for about 250 delivered, I have one and will take pictures if needed.
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 01-09-2012, 04:33 PM   #19
tubbedII
needs more $$$
tubbedII's Avatar
I looked up their website, and it doesn't show anything in their manifold section.
For the money, I don't think you can beat accuair's manifold set up.
1970 2wd Blazer
Old 01-09-2012, 05:38 PM   #20
made2drag
made2drag's Avatar
thanks!
Old 01-14-2012, 07:47 PM   #21
BuiltwithIvy
here is a pic of their setup, Check out their ebay store... couldn't have been easier to install and wire up, fbss along with a cheapo 5 switch setup from thorbros
1930 Tudor Sedan
Old 02-23-2012, 03:51 PM   #22
made2drag
made2drag's Avatar
hey man, is there only one airline from the tank feeding that?
Old 02-23-2012, 04:10 PM   #23
DLOE65
DLOE65's Avatar
Those SMC fittings are good, but not DOT approved. The elements and road heat make the plastic brittle and you will end up busting those. SMC makes DOT fittings that are all Black, you see them on Semi trucks. Get them at Fastenal.
Old 02-23-2012, 11:51 PM   #24
blime81
Laid Lo
blime81's Avatar
BuiltwithIvy, I'm not trying to bash on your ride but that doesn't look like the best spot for a manifold like that.
Even if you don't take DLOEs advice on those valves, you should at least move them, enclose them or make a skid plate to protect them.
Might be the angle of the shot but the bottom valves look like they are begging to be knocked off by a piece of road debris.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
