#1 | |
It's Better With Nitro
Re: Triangulated Vs. Parallel Vs. Pro- Street 4 Links
What is your primary goal for the truck (how much street v. strip driving do you honestly plan for the truck)? If your plan is mostly strip, are you willing to actively monitor your instant center and pre-load, and make adjustments according to track conditions, etc? I usually explain to friends and customers that a triangulated four-link eliminates the need for a housing centering device (panhard bar, watts link, track locators, wishbones, etc.). Most street parallel four-links do not permit as much adjustability as a drag race type four-link. As far as brands, I've installed many kits from Chris Alston's Chassisworks, and a couple from Art Morrison. Both companies offer different types of four-link systems, so check them out to see what fits your budget and plans for your truck. http://www.cachassisworks.com/cac_products.html http://artmorrison.com/homepage.html
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
