Re: Modern Gas
How do you make the carb alcohol resistant? I ponder the phase separation problem often. It really sucks. I know of no additive that will stabilize fuel for more than a short while,when it comes to a vehicle that doesn't run through a tank of gas every few months. My tow truck sits with a good bit of ethanol junk in it right now. I had to rebuild the carb. Now it runs,but I can tell the fuel is bad. It's hard to get running,doesn't make power and the exhaust burns your eyes. I have a whole bunch of additive in there. I'll have to drain that crap (how do you even dispose of old gas properly?) and my solution is to only keep a small amount in the tank. At least then when it goes bad you aren't wasting as much. The problem is,no matter how much I keep i there,it will have to sit through the winter. I'm worried about what sits in the carb.
My solution?... I'm seriously thinking about using small amounts of Cam2 in any vehicle that is just sitting. Isn't that alcohol-free? Or maybe aviation fuel? Those fuels are expensive,but I only need a couple gallons and at least you can use "all" of it and not dump most of it because it barely burns anymore.
Re: Modern Gas
{nm}
Newbee
Re: Modern Gas
Gates green hose seems to hold up well to the alcohol.
Av gas, or a race gas will keep very well for storage. Actually running your truck on it would cost a fortune. I have left my toys sitting for a year with Turbo blue, or Sunoco 110. |
![]() Join Date: Oct 2010
Re: Modern Gas
Kinda like a do on all of our quads and dirtbikes, turn the fuel petcock off and let it idle til it dies. Then you don't have to worry about the carb.
Re: Modern Gas
Here is what I do:
In the summer my truck gets more regular use so I don't do anything. All my engines have modern valves and guides and whatever else my rebuilder said I needed to do to combat unleaded gas. What special-K is talking about - phase separation - you have to deal with constantly. My truck gets a plow installed and both tanks filled in early November every year. That gas isn't used up until the end of March. For those tanks full I measure out the correct amount of Sta-bil (read the label and use the long term storage mixture). Pour it in after you get to the gas station and pour your gas on it so it mixes good. ONLY use non-oxygenated (ethanol free) gas in this mixture. Non-oxy is more resistant to phase separation and Sta-bil claims they combat phase separation. On my truck I then make sure I run a gallon or two out of each tank so I know the stabilized gas is in all the lines and most importantly in the carb bowl. Each state is different but I know that here in Minnesota if it doesn't say non-oxygenated, it DOES contain 10% ethanol. The non-oxy comes in premium only and costs more but a couple pennies per gallon in my opinion is way better than rebuilding a carb. I'm no expert but after numerous free implements given to me because they don't run any more I have observed that all the bad effects occur in the carb bowl. I don't know how many Briggs-n-Scrappem carb bowls I've dropped, cleaned, clean the needle and seat, fresh plug, and I got a free running lawn mower. (Or snow blower or chain saw or weed whip or ...) So long story short, treat the gas. Then make sure that treated gas is in your carb before you let it sit a while. Oh and speaking of small gas engines, I only run non-oxy in ALL of them ALL the time. Three outboards - all non-oxy. Three lawn mowers - all non-oxy. Chainsaw, snowblower, powerbroom, weed whip - all non-oxy all the time. I NEVER deal with gas issues. Ever. And I'm pretty sure it is because I always fill my jerry cans with non-oxy.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: Modern Gas
Thanks Mrien3 in the Wash DC area there is only 10% ethenhol what i did when I put it away for winter was put Amsoil gas stablizer in it while i filledI it up , I bought the truck already restored so I'm repairing some things, thanks for the tip on the Gates Green Hose.
Looks good at 20-ft .....
Re: Modern Gas
On yesterdays day-long Barret-Jackson: "OMG, How can there be that many people out there with that much $$$$" to blow show," there were ads several times for Sta-Bil's Ethanol Fuel treatment-stabilizer product.
Don't know if it's any good or not, but they were sure trying to convince folks that it was, to handle just these sorts of problems. |
![]() Join Date: May 2011
Re: Modern Gas
visit pure-gas.org to see if there are any ethanol free gas stations near you. Unfortunatally not near me. I used to run my Race car on Avgas. But I was informed that the 100LL (Low Lead) still has way more lead in it than even leaded race fuel and can cause deposits and engine damage. Never found out if this is true or not and I sold my Race car before I heard this so it never mattered to me. There was a time I ran avgas in my lawn equipment because I was just so sick of killing small engines inside a year or two. But I didnt think breathing all the leaded gas smoke would be to great either. Now I just grin and bear the crap fuel we have. Sure like to see some real good solutions!
I can tell you my truck ran the same on the original fuel from 1993 that smelled like varnish as it did on the first tank of high test. Thats impressive! |
Re: Modern Gas
Gates has whats called Barricade gas line now. Its approved for use with leaded and unleaded gasoline, diesel, biodiesel, e-85, 100% methanol, ethanol and gasohol fuels.
Scrapper 1
I have hear about this problem But with new car's and trucks running the same fuels they have new hoses to keep form the new fuel eating the hoses they have that blue liner inside the hose.
Now about the new gas I know of a few old farmers that still have some of the lead additive that they use and I know Canada and Mexico you can still buy it like the old R12 in Mexico. I like the peacock idea dose work cus on lawn mowers they say to do the same thing.So i think that's a grate idea But for most of us OLD PEOPLE you need to put something on the dash to say turn PEACOCK ON for fuel Dummy. Whe ever said use the Peacock thank you My 1971 and 1972 will love you long time |
#12 | |
Re: Modern Gas
Re: Modern Gas
Just to note, when you rebuild your carb buy the kit from Cliff Ruggles. He is the only person that I know of (there may be others) that sells the inlet needles and accelerator pump seals that Ethanol won't destroy. The kits bought at Napa. Oreilly and others will not have the good seals and it won't be long after your rebuild that it will need to be done again if you have to use today's crappy gas.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Re: Modern Gas
I run no ethanol in everything, all the time. We have 4 vehicles that are daily drivers and we always use no-ethanol. I have checked the mileage and I get about 70-80 more miles per fillup which is about another 3-4 miles per gallon. Yeah, it is about .15 a gallon more but it way more than pays for itself in the mileage. All of my concrete grinders and small engines, nothing but no-ethanol, the ethanol gas is really bad on small engines. I put a completely rebuilt engine in the old brown '68 truck, new everything. It started running really badly at about 600 miles, rebuilt the carb and checked the pcv valve, there was about an 1/8" gunk laying in the bottom of the pcv valve. That is when I went to no ethanol in everything. It turned out to be I needed to run a 12 volt wire to the new hei, I forgot when I put the motor in it. When I take the concrete grinders out I take 10 gallons of gas with me. When I travel, I still take 5 gallons of no-ethanol to pour and mix with the crap you buy now in case I cannot find any.
No one ever fell to the top of a mountain. When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend - ![]() |
#15 |
Re: Modern Gas
Even when driving a car/truck now and then the fuel still breaks down into varnish goo sooner than it used too. I always keep a carb kit on hand and every so often put a new kit in. Never did this most of my life, used to let fuel sit for a few years when it had lead in it, not now, sucks the stuff they pawn off on us. With today's technology you would think there would be a better solution. I know cool fuel breaks down a lot slower than warm fuel.
#16 |
Re: Modern Gas
Not sure how it is where everyone else is but in Kansas Ethanol was labeled on the pump when it showed up and almost everyone I know would avoid it like the plague. A couple years ago laws were changed here and now the pumps are NOT labeled
so you can't avoid it even if you wanted to. Jeff
#17 |
Re: Modern Gas
I deal with this everyday in the marine industry. Last week I had to clean 2 outboards out that had phase separated fuel. (I'll Post pics tomorrow). I also am changing my fuel lines to outboard fuel line, it's us coast guard approved for ethynol fuels. I've yet to have it come apart.
I run my cars (except the TA) 2-3 times a month to keep the fuel moving. And I add a little av gas. Seems to work so far. Posted via Mobile Device
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#18 |
Re: Modern Gas
Fuel stabilizers are a good thing,and I use them. But,they only extend the life a few months. When you run an engine occasionally you move deposits out of your bowl,but through the carb,and replace the fuel in the carb with the same phase separated fuel. It does help to run it but the longer that same gas is in your tank the worse. The problem is with vehicles you can't start for a long time for one reason or another. All my life that never mattered,unless something sat a crazy long time. This crap now is shamefully ridiculous crud that you really don't even want in your carb.
#19 |
Re: Modern Gas
Here is some phase seperation.
We put startron in every boat, everytime we fuel it up. Seems to be working ok, the boats i have to fix are the ones that sit for a couple months on trailers and did not use a treatment.
#20 |
1969 Custom 30 wrecker
I can't believe our officials force this stuff on us! I HATE politicians!!!!
![]() I'd like to make them drink it! ![]() I'm very surprised no one on this forum has mentioned about the ethenol tax credits ending. Congress let that expire so no more 6 million of that tax payers money going to fund it. Of course, that will probably only drive the cost at the pump even higher for us!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#21 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Modern Gas
I've got a drum of 76 110 octane that has been sitting for about 8-9 years, how do I check this to see if it is any good?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#22 | |
Newbee
Re: Modern Gas
You could run your lawn mower on it for a Loooooong time ![]() |
#23 | |
Florida Edition
Re: Modern Gas
#24 |
![]() Join Date: Feb 2008
Re: Modern Gas
Sta-Bil is the additive I used at work on all our small engine needs and we have had zero problems, even on units that sit for six months. I also use it in everything I own. Todays gas has a shelf life of about 30 days so you need to use something.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
