Power Steering hoses ?
I have a 71 frame that I bought with power steering , I am about ready to start and drive it. I bought new stock power steering hoses but I am having a hard time determining how they are supposed to be installed. The pressure line has some crazy bends in it.A picture or a description would be helpful. Thanks
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Is it 2wd or 4wd I have both and could take some pic's to help you out just let me know.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
It is 2WD ,That would be very helpful. Thanks
ttt
PROJECT 7DEUCE
Not sure if this will help you or not
PROJECT 7DEUCE
one more
p/s pump in the above pics is not stock mounted to engine block,is higher than factory, even the prop valve location is not factory,
Thanks FrenchBlue but I am having a hard time seeing the power steering pump in the pictures,mine is located very low on the block,it is actually mounted to a bracket that is mounted to the motor mount. Thanks for the effort ,I appreciate it.
PROJECT 7DEUCE
My powerr steering pump is not even on the motor how can it be mounted higher than stock??? Y es I moved the prop valve.
Steering hose pics
RShaips,
I changed over my 71gmc with a 307 V8 from manual steering to power steering a couple months back. Here are some picks of mine. Hope it helps you out! ![]() ![]() Josh
72Chevy swb 4x4 71GMC swb 2x4 |
Gearbox pic's.
PS mine is a 2wd. Good luck.
Josh
Thanks ,I think thats what I was looking for. It seems like a simple thing to do ,but I bought stock hoses and they had some strange bends , Thought I'd ask before screwing it up. Thanks for the help
