Vacuum ?
The vacuum on my rebuilt 275Hp 327 fluctuates between 6 & 9 Hg. . Cant find any vacuum leaks , Any Ideas ?
If you have ruled out the carb and vacuum leaks, and the engine has new plugs, etc., I would try reseting the valves. Even though it is messy, I prefer setting them hot with the engine running. I use tabs on the rockers and a cut-off valve cover to minimize the oil splashing, loosen the nuts until the rockers click. Tighten the nut until the noise goes away and tighten an additional 1/4-1/2 turn.
If that does not help, I would check the compression and go from there. Jim |
Set the valves at 1/2 Turn , new plugs , pulled the plugs & there still running rich , have the carb leaned out one turn from seated.
its all about the +6 inches
Depending on your cam specs, that may be all the vac you can get out of it.
I'm running a 272 Energizer Cam , & I have a Fluctuating Hg. Reading , so i'm thinking i have a leak somewere?
I would bet a vacuum leak around the intake or one of the ports/hoses. Block off all hoses and use a short length of garden hose and listen as you move that hose all over the top of the engine. You may find that leak.
Car Knocker
I have never tryed the garden hose route. I always use carb cleaner and spray around intake, carb, vacuum lines, and if engine speeds up you found your leak. Timing right, I maybe wrong but if it is retarded it with show low vacuum.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
