Old 09-30-2011, 12:42 PM   #1
8baller
my 57 ..project
recently picked this truck up...going to get started on some things but it's going to be a slow build ...
8baller is offline   Reply With Quote
Old 09-30-2011, 01:07 PM   #2
bajabob
bajabob's Avatar
Re: my 57 ..project
nice project, I think its mandated in the agreement when you signed up here that u must state your intended direction..... run as is, blow it apart, slam it, lift it... motor, trans...etc
please advise
especially like spare tire set up.....
bajabob is offline   Reply With Quote
Old 09-30-2011, 01:43 PM   #3
8baller
Re: my 57 ..project
please advise
has a newer small block in it that does'nt smoke and runs great(was told it was recently rebuilt)all new gaskets and the way it runs no reason to doubt it
350 trans(needs rebuilt)
has a camaro subframe..after looking at it i am going to pull the cab and box it in..(just make me feel better if i do)
has 4 wheel power disc brake..
dont know what i want to do with the rear suspension..would like to run a 4 link with bags..have'nt decided
bed floor is just a piece of plywood...going to figure what to do with that after i decide on suspension
as far as the spare tire set-up...i really dont know if i like it or not...depends how i go with the build...if i decide to bag it ..will the tire hit the indention in the spare fender?..
right now i am running alot of ideas through my head...
honestly though i want to build a summer every day driver out of it(not really a car show person)..be happy if i can just get the body off and rebuild the suspension and get the whole chassis done and painted and body mounted again by next summer and do the body next winter...just trying to be realistic about my timeframe and money
Old 09-30-2011, 01:53 PM   #4
8baller
Re: my 57 ..project
one more thing...i am thinking about using some straps and hoisting and hanging the bed up to these wood joist(space saver)...not really sure how heavy it is but i have limited space in the garage and was curious if it would be a bad idea...
once i sell off my old mustang parts i'll have plenty space to work..but until then i am stuck with this or storing it outdoors in the elements
Old 09-30-2011, 03:01 PM   #5
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: my 57 ..project
Whatever direction you decide it looks like a nice project to start with. Good luck to you and keep posting pictures.
Kabwe is offline   Reply With Quote
Old 10-01-2011, 12:06 PM   #6
8baller
Re: my 57 ..project
thanks ...and sure will...
Old 10-01-2011, 02:42 PM   #7
8baller
Re: my 57 ..project
anybody fill me in on how to tell what year the camaro subframe on my truck came from?..will there be some numbers somewhere..the upper control arm has D16J9R stamped onto it..
or are they generally the same all years of the second gen camaro..
want to get on rebuilding the front suspension and want to get the right parts
Old 11-08-2011, 10:53 PM   #8
8baller
Re: my 57 ..project
anybody tell me what rear end this is
Old 11-08-2011, 11:19 PM   #9
C.shows
C.shows's Avatar
Re: my 57 ..project
looks like a nice start! Look on the steering box there should be a # stamped on it..
Google is your best friend when it comes to ID #'S.. same with that tag on the reared.
Good luck keep posting pics. P.S. we broke a roof joist doing the same thing in our shop! use caution! lol!
C.shows is offline   Reply With Quote
Old 11-08-2011, 11:24 PM   #10
8baller
Re: my 57 ..project
the tag on the rear end says limited slip differential fluid only..
and i gave up on the idea of using roof joists for anything.. gonna get a shed and empty the garage of non garage items..mower tiller etc etc..
then i'll have the space to utilize the cherry picker to remove the bed and cab..
Old 11-08-2011, 11:34 PM   #11
C.shows
C.shows's Avatar
Re: my 57 ..project
Mmm.. There should be a number on the pass. side in the casting.
Old 11-09-2011, 01:41 AM   #12
8baller
Re: my 57 ..project
there is one on the driver
K08D
Old 11-09-2011, 02:05 PM   #13
OrrieG
OrrieG's Avatar
Re: my 57 ..project
what is the span wall to wall and joist size ( looks like 2x8).
Old 11-09-2011, 02:14 PM   #14
8baller
Re: my 57 ..project
i gave up on the joist idea...going to order me a yoder built shed and load it with non garage bs
Old 11-09-2011, 03:14 PM   #15
8baller
Re: my 57 ..project
so i made a phone call to the guy who actually built the truck to the point it is at..turns out alot of the info i recieved from the guy i bought it from is off..
was told that it's a caddy stub up front and a caddy rear...
any caddy guys here identify any of this?
Old 01-04-2012, 03:32 PM   #16
8baller
Re: my 57 ..project
a little progress..
first time i ever patched anything..came out ok...
found the original color also...
Old 01-04-2012, 04:29 PM   #17
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: my 57 ..project
The patch looks good, keep working at it.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-04-2012, 11:00 PM   #18
8baller
Re: my 57 ..project
started doing the drivers fender today...got cold and called it a night
Old 01-05-2012, 01:27 AM   #19
Kim57
Kim57's Avatar
Re: my 57 ..project
Your patches came out real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-05-2012, 01:55 AM   #20
8baller
Re: my 57 ..project
Kim
thanks kim..i am clueless when it comes to bodywork..been lurking in this and a few other forums for a while researching what other people do with what i need done and have just been trying to duplicate ...
only thing that really matters to me is if it is solid when it's done and how much materials and wood i'll be able to haul..just wanted a cool work truck
Old 01-05-2012, 02:04 AM   #21
longbike
longbike's Avatar
Re: my 57 ..project
That does look great!
Did you by chance hold your fender up to the front side of the doors to see how it lines up.
My lower patch panel was bowed way out, yours looks good! what patch panel do you go with?
longbike is offline   Reply With Quote
Old 01-05-2012, 02:24 AM   #22
8baller
Re: my 57 ..project
sure did...not a change from the rusted bondo filled junk i cut out of it...
actually bought these when i was on vacation from a place in huber heights (dayton) ohio called restoration world...www.resto-world.com...
just laying them on the old fender they fit like a glove
Old 01-05-2012, 05:27 PM   #23
8baller
Re: my 57 ..project
pulled the bed today to get access to the cab corners....
thank goodness for the cherry picker
Old 01-05-2012, 10:01 PM   #24
Spackle100
Re: my 57 ..project
Nice start! If you don't mind, what are the dimensions of the fuel cell? It looks like it fits real well.
Spackle100 is offline   Reply With Quote
Old 01-06-2012, 01:28 AM   #25
8baller
Re: my 57 ..project
dont know the dimensions...but i'll measure it tomorrow..i actually have a new 67 mustang tank from an old project in my basement that i was thinking about using...still up in the air though...just want to fix all of the rust and whatnot now
