Velocity Speed Shop
Trailing Arm Bushings!!!!
Does anyone know the best way to remove the bushings from the trailing arms? I have new poly bushings that I want to replace the old ones with.
--------------------------------------------------- My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143 My Garage ..... http://www.hubgarage.com/mygarage/OCD69 |
Happy to be here
![]() Join Date: Mar 2000
Re: Trailing Arm Bushings!!!!
They need to be pressed out. You can use a torch to burn them out, but it is a nasty process.
is there a way to press them out while the arms are still under the truck?
#4 | |
I did mine with a propane torch, I concentrated the heat on the inner sleeve instead of just trying to melt out the rubber, that way once the inner sleeve slid out with a screwdriver the rubber pushed right out.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Watch out for your cornhole !
![]() Join Date: Jun 2003
You need to figure out if your new bushings reuse the old outer shells or not. Some do, some don't.
If so, just set the rubber on fire and it will burn out. Clean the shell with a wire brush and you're ready to install the new bushings. If not, you definitely need a press or a real strong air hammer.
My poly bushings required the outer shell which made it easier on me to replace. All I did was drill holes into the rubber between the shell and inner bolt sleeve. Didn't take long. I made like 8 or 9 holes then stuck a big screw driver in the bolt sleeve and pryed it out. I then used a wire brush to clean out the shell.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() Last edited by AusTx68; 08-31-2009 at 06:15 PM. |
Happy to be here
Good idea. Much less of a mess than burning them out.
#8 | |
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Drilling it is.....i am replacing mine this weekend.
any idea what size wrench you needed for bolts? I have a 1 1/16 is biggest and it wasnt big enough! time to buy a new tool
1977 Chevy C10 RWD long bed |
#11 | |
This is how i also did mine
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
mine were 1 1/8" if I remember right.
I'm just glad to be here!
1 1/8" wrench is correct. I just took mine off the other day...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Grandpa in the rustmobile...
Yeah I think aggie is right.
I pressed mine out with the 20 ton press. Easy squeezy lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
