Old 10-02-2011, 08:31 PM   #151
mx574
Re: Long to short conversion
thanks again for the words of encouragement. the shop progress is behind. my buddy wanted to paint the floor before moving all stuff in. paint was hard to find had to order and get it shipped. it did not get painted until thursday. basically truck gets worked on one day a week right now on tuesdays. this last tues we mounted pedals, then the booster/master and figured out and mounted the hydraulic clutch master. it is getting dark earlier so not much progress each day. dyeing to get my truck to the shop. i do not think of taking pics while workin on it and truck is in one car garage so taking it out to take pics not convenient. but today painted pedals and mounting brackets for rear calipers
mx574 is offline   Reply With Quote
Old 10-04-2011, 10:38 PM   #152
mx574
first is the booster/master and the master cylinder for the hyraulic clutch. 2 is engine with the serpentine sstem installed. 3 is all the fatmat installed, i still have more hushmat(sucks compared to fatmat) maybe i will put on back wall of cab. 4 and 5 are pics of the exhaust. there was very little room so i did not run the flowmasters that were on the truck before. i will post more pics in a minute that show exhaust tip better, comes out right in front of the tire so should scare all the neighborhood kids
Old 10-04-2011, 10:57 PM   #153
mx574
okay so today good and yet very bad. i wanted to get started on the rear brakes and tired of waiting for the shop. so obviously remove diff cover, pin and axles. removed the old backing plates so gone are the old brakes. now, ordered rear disc setup from POL and said i wanted axle bearings and seals. POL only had seals not bearings. I got bearings from Early Classic in Fresno. bearings went in they are good. Seals are not, thanks POL . Then i went to move forward and install the caliper mounts to the axle, also POL and they DO NOT FIT. I tried every possible bolt pattern and different holes. I am so pissed. I will have to return everything then go to CPP i guess. pic # 1 is another shot of the exhaust to give idea of how it looks from outside. tucked pretty high, i did not want it to be too noticeable. 2 is my main man he just turned three and thinks the truck is "cool". 3 is the eaton posi. 4 is the bearings and wrong seals. 5 is the axle housing minus the bearing and seal and i stopped taking pics when i found problems. i did make it to auto zone which had timken seals so rear end is bolted back together minus rear brakes.
Old 10-13-2011, 08:30 PM   #154
mx574
so truck is getting wiring/brakeline/fuelline run. Supposed to fire it for the first time in about a week. WOOHOO. So i figured i should start looking into getting it re-registered and insured. If i want to register it in California. NEXT Year 2012 from 12-31-2011 to 12-31-2012 is $126.00 if i want to drive it now that will be $145.00 from now until 12-31-2011. AWESOME. No wonder why CA is in the crapper. i am so pissed
Old 10-29-2011, 04:10 PM   #155
mx574
well i have two short videos but i cant seem to get them on here. we ran the truck for the first time on thusday night. it still has a ways to go-brakes driveshaft- but theres enough there to make it burn fuel. sounds very healthy just starter needs to get shimmed.
Old 10-29-2011, 04:17 PM   #156
63chevyll
gets board easy.......
63chevyll's Avatar
I didn't look back through but what clutch master did you use.
Good looking build BTW
63chevyll is offline   Reply With Quote
Old 10-29-2011, 06:55 PM   #157
mx574
it is a willwood master cylinder but i just bought the hydraulic clutch kit from mcloed and that is what it came with.
Old 10-30-2011, 01:38 AM   #158
mx574
http://vimeo.com/31316853
here is link to first video. will try to get the other one up tomorrow
Old 10-30-2011, 02:43 AM   #159
Hatzman
Hatzman's Avatar
MX574, Great project!
What gas tank did you use? I have a 1970 C10 and am having probelms finding a gas tank that does not hang down too low... Yours looks like it fit well.
Awesome looking truck!
Hatzman is offline   Reply With Quote
Old 10-30-2011, 11:29 AM   #160
mx574
hatzman- i bought it from brothers trucks. if i had to do it over again i would get a different tank. i on a budget and got the one that says "Popular conversion" part GTPDS72 cost is 239.99. After i got it i found out it is just a blazer/suburban tank so the filler tube needed fabrication to work. It basically comes out of the tank and goes straight into the framerail in which i think blazer/suburban have a hole there. I welded that one up and drilled my own hole in the center and made my own bung from a harley to go in the bed floor. They are a lot but an aluminum tank is what i would do and they are basically custom made for our trucks but production now. Brothers has one # ATK6372 but cost is 469.99. hope it helps. but no my tank does not hang too low. good luck
Old 10-30-2011, 06:11 PM   #161
mx574
http://vimeo.com/31337634
timing
Old 10-30-2011, 07:58 PM   #162
rondog4416
rondog4416's Avatar
where did the front drive setup come from ? i like the fact that the alt is down low thanks ron
rondog4416 is offline   Reply With Quote
Old 10-30-2011, 08:27 PM   #163
mx574
yeah the guy that is helping me could not believe how nice for the price. good old summit, it is a summit brand serpentine kit. cost was 379.00 and it included 4 pulleys, two mounts, two belts, and all the hardware.
Old 12-01-2011, 08:34 PM   #164
70-Shorty
any updates?
Ontario CA•70 Chevy Shortbed Fleetside C-10
71 Chevy Longbed Fleetside C-20 (sold )
63 Chevy II Nova SS
02 Ford F-150 Harley-Davidson supercharged 5.4
2000 Harley Roadking Hot Bike Baggers Mag Shoot
http://s263.photobucket.com/albums/i...oot/?start=all
some truck lettering & flame jobs
http://www.flickr.com/photos/4950319...7602894916215/
70-Shorty is offline   Reply With Quote
Old 12-16-2011, 10:41 PM   #165
mx574
tim- thanks 4 checking up on me. i have been busy with work and the truck. it has made a lot of progress. i will update soon. it drove under its own power tuesday. wiring 99% done. air is fully done, clutch fully done, brakes fully done. i got windows installed yesterday and i got tires put on my rims 2 day. check back i think u guys will likey
Old 12-17-2011, 04:47 AM   #166
68 TT
Still plays with trucks
68 TT's Avatar
Nice looking truck. You have done a great job with it. Keep it up.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 12-17-2011, 12:48 PM   #167
mx574
thanks 68 tt. going to work on it 2day and hopefully get some pics on here. i am killing time as i try not to fire it up too early. it is quite loud and i think my neighbors hate it. but i get so giddy everytime i get to turn the key.
Old 12-17-2011, 10:20 PM   #168
mx574
today did not go as i planned and i did not get much done. updated pic of the motor with brakes, clutch, wiring and air filter. interior as of today. i still need to do brake lights and brake switch, mount the battery box then i can mount the pass seat. and the rear meats
Old 12-17-2011, 10:27 PM   #169
mx574
i knew my track bar needed final adjustment but i did not think it was that far off. when i went to mount the wheels it was about 3 inches off to the driver side so the pass rear was hard up against the inner wheel tub. adjusting it and getting it right and the bolt put bake in turned out to be another nightmare as there have been maaaany in this process. but it is adjusted and the rear end is centered and the tires fit woohoo
Old 12-17-2011, 10:36 PM   #170
mx574
we went to a 5 year old birthday party today and this showed up
Old 12-18-2011, 01:23 AM   #171
68 TT
68 TT's Avatar
I know my neighbors hated my 67 C10 with the big block and 3" Flowmasters. It used to rattle the walls of their house when I fired it up. I loved it though and my stepside will have the same system but with full tail pipes this time to knock just a littlle of the rumble down.
Old 12-18-2011, 01:27 AM   #172
68 TT
68 TT's Avatar
I guess that is one way to write off the Vette on your taxes.
Old 01-05-2012, 01:39 AM   #173
cagodinez
cagodinez's Avatar
Your truck is turning out nice, hope to see you at the Brother's show this year.
cagodinez is offline   Reply With Quote
Old 01-11-2012, 02:05 PM   #174
tattoed71
tattoed71's Avatar
very nice paint work whats the color called
paint dont make u go faster
tattoed71 is offline   Reply With Quote
Old 01-19-2012, 10:07 PM   #175
mx574
where are you in socal. my broinlaw has a nice mustang and we made it out 2 of the last 3 saturdays. maybe we can meet up. dont need to wait till the brothers show
