Old 01-04-2012, 09:45 PM   #1
C4 Metal Werks
C4 Metal Werks's Avatar
Lower Ball Joint Fell Out
We replaced the upper and lower ball joints when we installed the air bags on my 66 and this morning the right front came out of the spindle and the left side cotter pin is broken and twisted in a way that could not happen even if the nut came loose. I'm a little worried. Anyone else had this issue?
I'm thankful that I was in a parking lot when this happened.
Low & Slow
C4 Metal Werks is offline   Reply With Quote
Old 01-05-2012, 08:34 AM   #2
PGSigns
PGSigns's Avatar
Re: Lower Ball Joint Fell Out
Did you make sure the joints you installed matched the taper on the spindles that were in the truck. Sounds like the ball joints are moving in the taper and beating the nut off the end of the ball joint.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-05-2012, 08:46 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I agree.
What year balljoints?
What year spindles?
Keith
Convert to disc brakes.
Old 01-05-2012, 11:02 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
^^Like what Keith is getting at, It sounds like you might have a parts mismatch between the balljoint and spindle. I've been messing with GM cars for 30 years, and I have never seen a balljoint come out of the spindle. Are you running stock control arms? When you ran the balljoint nuts down, did you snug them up tight, then back off the nut to the nearest castlation to get the cotter key installed? Were the balljoints full of grease? Basic questions, I know, but I had to ask.
The taper that PGSigns is talking about is vital to keeping the interference fit between the spindle and the balljoint. Do you by chance know if anyone has modified the spindles?
Also, if you do rebuild the front again, don't skimp on balljoints and buy the cheapest stuff. Spend a little extra and get the right ones....Moog. Made in the USA, pretty rare nowadays.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
