![]() Join Date: Feb 2011
some axle ?
i got a 70 gmc with 12 bolt 6 lug wanna swap it 2 5 lug
whats best way of doing this i was reading around a c that a ford 9 with disc from a 75 ish lincoln will fit whats the gear ratio normly? can i swap the gear ratio 2 like 3.73 or should i get a 12 bolt from a 73? i really wish the axle from like new tahoe with disc brakes would fit but its like 67 inchs wms lol |
Re: some axle ?
The older Lincoln 9" rears prob had 3.00 gears. They're alot harder to come by vs just buying some replacement 5-lug axles & swapping them into your current rear-end.
The 12-bolt from a 73 will be slightly wider than the current 6-lug (.750 each side 1.50" total width increase). Not to difficult to overcome, but something else to keep in mind.
Re: some axle ?
The versailles/granada gear ratios was 2.48:1, 2.58:1, and 2.75:1 and its 58.50 inches wide.And the 28 spindle axles in them can't be shorten so if the axle isn't the right size pass on it.
