Wipers are slow, then stop.
I have a 79' GMC with the standard two speed wiper switch. After the wipers have been running for a while they will start to slow down then eventually stop. If I leave the switch "ON" they eventually start back up. If I turn the switch "OFF" and "ON" a few times eventually they come back on. When the wipers come back on they work fine for sometime and other times they don't.
Re: Wipers are slow, then stop.
check the switch and wiring and defianatly your wiper motor its prob that
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
Check your fuse, mine was having similar issues and I took the fuse out and cleaned the contacts, and it solved it.
![]() 305 ci | TH350 | NP208 | 60k miles |
78K & 79C Jimmys
My 78 jimmy switch pushed out the back
Was ez to fix , the switch posted in thread below Sometimes the copper ground strip is bad/green Posted via Mobile Device
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
a while ago i was driving at night and my lights dimmed and my wipers slowed down to a snails pace. it ended up being a connection to my alternator, it was loose adn dirty. i cleaned it up a little and plugged it back in and it fixed the problem.
![]() Join Date: Nov 2011
The first thing I always check in this situation is the ground wire. 9 times out of 10, its going to be the issue with the symptoms you describe.
