Closed Thread
Old 01-06-2012, 02:25 PM   #3226
502ms
502ms's Avatar
Re: What did you do to your truck today!
Originally Posted by BigCountryx View Post
Tried to kill it!
remedy:
Best Regards,
Leon M.
502ms is offline
Old 01-06-2012, 02:32 PM   #3227
BigCountryx
BigCountryx's Avatar
Love the stepper and yes. Miss my train horns from my old truck. Another set will be on this one when the bags go on
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline
Old 01-06-2012, 06:13 PM   #3228
xb9rguy
xb9rguy's Avatar
Bought my truck a sport bumper in pretty good shape (couple small scratches and needs cleaned real good) and dakota door seals for $70 at the local pick-n-pull.
Jeramy
CURRENTLY OWN,
72 c10 project/driver
2010 Kia Forte Koup SX daily driver
88 cherokee wheeler and dog hauler
2001 drz 400
Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles.
xb9rguy is offline
Old 01-06-2012, 11:19 PM   #3229
502ms
502ms's Avatar
thanks! that will be a good move...
Best Regards,
Leon M.
502ms is offline
Old 01-06-2012, 11:20 PM   #3230
502ms
502ms's Avatar
sorry for the repost..pics above
Best Regards,
Leon M.
502ms is offline
Old 01-07-2012, 02:17 AM   #3231
ItsRandy
ItsRandy's Avatar
Sanded my bed with #400. Found and filled a few more small low spots/flaws. I will finish sanding and then spray the final coat of primer this weekend...maybe tomorrow. Then one more round of block sanding, spray some sealer and on with the color...I think by next weekend! I'm so syked!
ItsRandy is offline
Old 01-07-2012, 07:11 AM   #3232
1967monster
took driver side fender off and worked on the other but there 4 bolts i cant take off giving me hell. hard to get to them the nut keep spinning they have that washer with lip on it cant get socket or wrench on them. whats the best way to get those off anyone????? not much but just start a couple days ago
1967monster is offline
Old 01-07-2012, 12:41 PM   #3233
lil hoodlum
lil hoodlum's Avatar
to the forum from North Texas.
I had the same problem. I used a good penetrant like liquid wrench and locked on a pair of vice-grips to the nut/clip part and undo the bolt. I also found out that I broke quite a few of the "J clips" during the process. You might consider purchasing some new ones for re-assembly.
Good luck!
Keith
lil hoodlum is offline
Old 01-07-2012, 01:45 PM   #3234
dukcaln
dukcaln's Avatar
got the new edelbrock intake and edelbroke carb installed and ditched the stock q-jet and factory manifold....wow what a difference in weight between the two and wow it looks awsome...will post pictures up when i finish and fire it up today...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 01-07-2012, 02:36 PM   #3235
chevy88
chevy88's Avatar
Installed/aligned my door back onto truck after being completely rebuilt.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline
Old 01-07-2012, 05:58 PM   #3236
dmwphoto
dmwphoto's Avatar
I installed a new rear wiring harness. The PO did some funky stuff with the wiring and it was a mess. As soon as I get some back up light cups I should be in business. Also need a license plate lamp.
dmwphoto is offline
Old 01-07-2012, 06:06 PM   #3237
1967monster
Good luck!
Keith
thank keith and chevy88 for the help ill try both today and let you guys know what happen.
Old 01-07-2012, 06:20 PM   #3238
Sicklajoie
The Niner
Sicklajoie's Avatar
Installed my core support filler panel.
Before
After
Can't believe today was January 7th...after I was done went for a nice ride!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 01-07-2012, 06:49 PM   #3239
BigCountryx
Did some custom body to add tire clearance, lol. At least I can turn both right AND left now. I guess that's progress.
Old 01-07-2012, 08:13 PM   #3240
Went backwards on the 70.
I needed a solid engine to replace my oil burner in the Hoopty and since I already stole the tranny out fo the 70 fir the 83, I decided rather than buy another new crate that I would steal this one to go into the 83. So today the 70 was stripped of its drive train.
Oh I forgot (at least by yourself) small blocks don't come out with long tube headers still hooked up. Other than that the ole crate is in the stand waiting for the day to do the swap into the 83.
Also installed a new stereo head unit into my 2002. One of the filters was going bad in the tuner section, so I swapped in a fresh unit. The Pioneer can do all the cool tuff too; MP3 CDs & Flash Drive MP3s plus blue toothie & Ipodee (don't care) stuff.
Palf70Step is offline
Old 01-07-2012, 08:24 PM   #3241
1967monster
got fender off yeah went plan b cut them off worked out good. they where in a bad place i couldn't get to them with a wrench.
Old 01-08-2012, 02:33 AM   #3242
ItsRandy
ItsRandy's Avatar
More block sanding the bed. I will be shooting the last coat of primer on it tomorrow, then block sand 1 more time and shoot color next weekend. I can hardly wait!
ItsRandy is offline
Old 01-08-2012, 02:25 PM   #3243
Delo69
Delo69's Avatar
Well my wheels and hubcaps took longer than a day but here is what I've done recently just waiting to save up some for new tires..I'm thinking 235/75/15 Goodyear Wranglers will look great.
What the wheels started out as:
After sandblasting:
After about 4 coats of rustoleum and a coat of clear:
Ebay hubcaps I bought started like this:
And ended up like this to match the truck:
_____________________________________
Dennis
1969 C10 250 w/3 on the tree - project/weekend warrior
2010 Subaru Impreza - daily driver
Delo69 is offline
Old 01-08-2012, 02:26 PM   #3244
dmwphoto
dmwphoto's Avatar
nice work Dennis
dmwphoto is offline
Old 01-08-2012, 04:26 PM   #3245
Sold it! I just sold my '71 SWB K/10,minus the Stepside bed.
special-K is offline
Old 01-08-2012, 04:59 PM   #3246
GRX
GRX's Avatar
Truck in my sig ... Been laid up from surgery for the past few weeks. Drove it around today for the 1st time in a while. Sure was nice! That was after I checked all the fluid levels, including the anti-freeze. Good to -20 degrees.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline
Old 01-08-2012, 07:18 PM   #3247
landsurvey1
landsurvey1's Avatar
I installed some running boards.
1972 Chevy short bed ZZ4 350/355hp GMPP crate engine.
1972 Cheyenne K-20 454/400hp big block
1988 Jeep Wrangler
2010 Jeep Sport Unlimited
landsurvey1 is offline
Old 01-08-2012, 10:01 PM   #3248
hayhauler71
hayhauler71's Avatar
Installed my home made heater delete set up
Fuzzy
hayhauler71 is offline
Old 01-08-2012, 10:02 PM   #3249
aventur1
aventur1's Avatar
looks good...you dont need a heater?
aventur1 is offline
Old 01-08-2012, 10:11 PM   #3250
hayhauler71
The heater hangs from the ceiling in the garage I don't drive it in the winter
Fuzzy
Closed Thread
