Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-26-2011, 11:05 PM   #1
tripovermyego
tripovermyego's Avatar
97 S10 Blazer gauges...
Ok so I traded my 94 Dodge Dakota ext cab 2wd for a 97 s10 Blazer 4wd. The PO had cut the dang factory wiring harness for the radio instead of just unplugging it from behind. Anyway, I went out today to wire it back up so I can have a radio. As i was wiring everything up, I made sure that none of the wires crossed or touched or anything. I got it all hooked up and turned the switch on and noticed that my fuel gauge, temp gauge, tach, speedometer, odometer, and the part that shows what gear your in no longer works. The oil pressure gauge and battery amp gauge works. Also so does the SES light. All the other lamps no longer come on. Anyone have a clue as to what happened? Also, the compass in the center console on the roof no longer lights up unless the headlights are on. I do have dash lights and stuff too.
"Slow is smooth, smooth is Fast"
"You only live once"
"All gave some, some gave all"
tripovermyego is offline   Reply With Quote
Old 12-27-2011, 04:21 PM   #2
tripovermyego
Re: 97 S10 Blazer gauges...
Noone?
Old 12-27-2011, 06:15 PM   #3
HotWheels4000
HotWheels4000's Avatar
Did you check the fuses?
84 C10 lwb
89 S15 Jimmy 4x4
HotWheels4000 is offline   Reply With Quote
Old 12-27-2011, 06:17 PM   #4
tripovermyego
Sure did. But if the fuses were bad, wouldnt the entire instrument panel be dead? The lights work as normal.
Old 12-30-2011, 06:05 PM   #5
cable666guy
cable666guy's Avatar
You really need a schematic. In the mean time, you could start chasing grounds. All that stuff in the instrument cluster is on one harness, the radio wires really shouldn't interfere with any of that. I installed stereos and car alarms back in the mid 90s and stuff like that almost always came back to a ground issue...Good luck...
cable666guy is offline   Reply With Quote
Old 12-31-2011, 04:47 AM   #6
tripovermyego
I figured it out. There is this valve looking thing that sits right next to the thermostat housing that was unplugged. I noticed it and plugged it in to see what it did and WHAM! I had gauges again!! Havent messed with it since. My service engine soon light is on. It comes and goes. Havent really worried about it to much as the Blazer is still running strong!
Old 01-07-2012, 01:04 AM   #7
cable666guy
Glad you got it figured out and that it was a simple fix...That SES light is just there to annoy you!!
Old 01-07-2012, 01:08 AM   #8
tripovermyego
Well I actually lied. It wasnt that valve thing under the hood. Cause the gauges screwed up again. It was some wires where the radio is. I had to take one thats purple with a white stripe and splice it to the yellow power wire for the gauges. Still cant figure out why they wont work unless the parking or headlights are on. But oh well. I can deal with turning those on until I figure the issue out.
